תאור
The DFM-562IS is a software modem card. It plugs into a PCI expansion bus slot of a desktop PC. It supports voice, fax and data transmission/reception. It's a high-performance CONEXANT-based modem card, and can be used to connect to the Internet, and for fax and voice communication.
מאפיינים כללים
Data transfer
• ITU-T V.90/V.92
• K56flex
• ITU-T V.34, V.32bis, V.32, V.22bis, V.22
• Bell 103 & 212A
• V.44, V.42bis & MNP 5 (Data compression)
• V.42bis & MNP2-4 (Error correction)
• V.80 (H.324 video conferencing interface)
Sending a fax
• V.17 (14 400 bit / s FAX)
• V.29 (9600 bits / s FAX)
• V.27ter (4800 bit / s FAX)
Voice
• Support for voice over the sound card application
Supported OS
• Windows 98
• Windows ME
• Windows 2000
• Windows NT4.0
• Windows XP
