חיפוש מהיר
תכונות המוצר:
Cable Modem
EOL EOS
תאור:
Using the Ethernet port enables you to use a single connection to
the Internet or use a router to connect multiple computers to the
cable modem. You can also use multiple IP addresses from your
cable operator when using the Ethernet connection. When using the
Ethernet connection, do NOT install the modem drivers. They are
only for the USB connection.
You must contact your cable provider and register the MAC address of
the modem. The MAC address is located on the label on the modem.
Below are two common ways to connect your DCM-202 modem to
your network. The diagram on the left shows the connection with a
broadband router. The diagram on the right shows the connection
directly to a computer.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
