תאור
Using the Ethernet port enables you to use a single connection to
the Internet or use a router to connect multiple computers to the
cable modem. You can also use multiple IP addresses from your
cable operator when using the Ethernet connection. When using the
Ethernet connection, do NOT install the modem drivers. They are
only for the USB connection.
You must contact your cable provider and register the MAC address of
the modem. The MAC address is located on the label on the modem.
Below are two common ways to connect your DCM-202 modem to
your network. The diagram on the left shows the connection with a
broadband router. The diagram on the right shows the connection
directly to a computer.
מאפיינים כללים
LED COLOR DESCRIPTION
Green
Orange-Blinking
Orange
Green
Green-Blinking
Green
Green-Blinking
Green
Green
Green-Blinking
Power
Cable
Status
ETH
USB
Cable modem is plugged in to an electrical outlet and
is receiving power
The modem is searching for the DOWNSTREAM
frequency
DOWNSTREAM frequency is locked. Searching
for UPSTREAM frequency
UPSTREAM frequency is locked
Modem is registering with the cable company’s
head-end
Modem is ready for data transfers
Valid Ethernet link status
Cable modem is transmitting/receiving data through
the Ethernet port
USB interface is connected
Data is being sent/received through the USB port
