חיפוש מהיר
תכונות המוצר:
שרת אחסון ShareCenter ל 2 דיסקים, עם תמיכה ב - mydlink
תאור:
ShareCenter Network Storage with 2 drive bays and support service mydlink DNS-320L is a handy solution for the sharing and implementation of backing up your important data by creating a personal "cloud".
Remote sharing
ShareCenter Network Storage with 2 drive bays and support service mydlink DNS-320L is equipped with file-Web-server that lets you download documents, photos and other multimedia files, regardless of your location. After setting the ShareCenter benefit from the convenient Web-based user interface to browse the list of available files. You can also use the mydlink mobile application to connect to and play music, view videos and photos directly on your mobile device.
Streaming digital media content with a built-in media server
Back up your digital media files for secure storage on the ShareCenter and take advantage of built-in media server, UPnP AV, received certificates DLNA ®. Follow streaming digital media content to compatible media players such as the PlayStation ® 3, Microsoft Xbox 360 ™, or
directly on the Smart TV. Also, streaming video, photos, music can be performed remotely via a mobile device.
Easy Installation and Setup
Installing drives in the DNS-320L is not difficult - just remove the cap and insert a 3.5 "hard drives SATA. Click on the latch to get access to the drive enclosure, and then install them. Convenient USB-port on the back of the ShareCenter can be used or to share a house or office to USB-printer, or to connect an external USB-drive to perform backups at the touch of a button. You can also connect an uninterruptible power supply (UPS) to monitor battery level, and ensure data integrity in case of power failure .
High performance and flexibility
ShareCenter supports hard drives in four different configurations (Standard, JBOD, RAID 0, RAID 1) in order to select the best of them, depending on your requirements. In Standard mode creates two separate hard disks available. JBOD combines both drives into one volume. RAID 0 combines both drives in a striped array for maximum performance using a compound Gigabit Ethernet. In RAID 1, the contents of one hard drive is duplicated on the other, providing maximum reliability. If one drive fails, the other will continue to operate separately as long as there is no replacement of a failed drive. The data is automatically copied to the new disk, allowing the array ShareCenter return to full level of protection, while maintaining the integrity of the files.
Technology D-Link Green
For users interested in reducing electricity bills and saving the environment, the products D-Link Green ™ provides environmentally friendly alternatives without compromising performance. The device uses the power management features hard drive and control the fan speed to reduce energy consumption, minimize noise and extend the life of hard drives.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
