DNS-320LEOL EOS
שרת אחסון ShareCenter ל 2 דיסקים, עם תמיכה ב - mydlink
היכן לקנות
תאור
ShareCenter Network Storage with 2 drive bays and support service mydlink DNS-320L is a handy solution for the sharing and implementation of backing up your important data by creating a personal "cloud".
Remote sharing
ShareCenter Network Storage with 2 drive bays and support service mydlink DNS-320L is equipped with file-Web-server that lets you download documents, photos and other multimedia files, regardless of your location. After setting the ShareCenter benefit from the convenient Web-based user interface to browse the list of available files. You can also use the mydlink mobile application to connect to and play music, view videos and photos directly on your mobile device.
Streaming digital media content with a built-in media server
Back up your digital media files for secure storage on the ShareCenter and take advantage of built-in media server, UPnP AV, received certificates DLNA ®. Follow streaming digital media content to compatible media players such as the PlayStation ® 3, Microsoft Xbox 360 ™, or
directly on the Smart TV. Also, streaming video, photos, music can be performed remotely via a mobile device.
Easy Installation and Setup
Installing drives in the DNS-320L is not difficult - just remove the cap and insert a 3.5 "hard drives SATA. Click on the latch to get access to the drive enclosure, and then install them. Convenient USB-port on the back of the ShareCenter can be used or to share a house or office to USB-printer, or to connect an external USB-drive to perform backups at the touch of a button. You can also connect an uninterruptible power supply (UPS) to monitor battery level, and ensure data integrity in case of power failure .
High performance and flexibility
ShareCenter supports hard drives in four different configurations (Standard, JBOD, RAID 0, RAID 1) in order to select the best of them, depending on your requirements. In Standard mode creates two separate hard disks available. JBOD combines both drives into one volume. RAID 0 combines both drives in a striped array for maximum performance using a compound Gigabit Ethernet. In RAID 1, the contents of one hard drive is duplicated on the other, providing maximum reliability. If one drive fails, the other will continue to operate separately as long as there is no replacement of a failed drive. The data is automatically copied to the new disk, allowing the array ShareCenter return to full level of protection, while maintaining the integrity of the files.
Technology D-Link Green
For users interested in reducing electricity bills and saving the environment, the products D-Link Green ™ provides environmentally friendly alternatives without compromising performance. The device uses the power management features hard drive and control the fan speed to reduce energy consumption, minimize noise and extend the life of hard drives.
מאפיינים כללים
Standards
• IEEE 802.3
• IEEE 802.3ab
• IEEE 802.3u
• TCP / IP
• CIFS / SMB
• NFS
• AFP
• DHCP-Client
• DDNS
• NTP
• FTP over SSL / TLS / FXP
• HTTP / HTTPS
• LLTD
• PnP-X
• UPnP AV
• USB 2.0
• Bonjour
• WebDAV
Supported types of hard drives
• Internal 3.5 "SATA I / II - Support HDD 3TB or: -1
Ports
• Port 10/100/1000 Gigabit Ethernet
• USB 2.0 port
• Power
Indicators
• Power
• USB
• LAN (on port LAN)
• HDD 1
• HDD 2
Functionality
Disk management
• Multiple hard drive configurations
  + RAID 0
  + RAID 1
  + JBOD
  + Standard
• Migration of RAID: from Standard to RAID 1
• The format of the file system: EXT4
• Scan Disk
• S.M.A.R.T.
• Support for Advanced Format HDD (Advanced Format)
Account Management
• User Account Control
• Account Management teams
• Quota Management User / Group
• Network Access Control
• Management of mounting disk images
Manage downloads
• Schedule downloads on HTTP / FTP
• Download Peer to peer (P2P)
Backup Management
• Schedule a backup from PC to NAS (D-Link ShareCenter Sync)
• Schedule a local backup
• Schedule remote backup
• Supports Apple Time Machine
• Backup USB-devices
• Backup Storage Cloud (Amazon S3)
Device control
• Browser support:
  + Internet Explorer 7 or above
  + Mozilla Firefox 3 or higher
  + Apple Safari 4 or higher
• The Wizard system (Win / Mac)
• Utility D-Link Storage (Win / Mac)
• Notification by e-mail
• Notification via SMS
• Journal system / FTP
• Function Print Server
Power Management
• Power Save Mode
• Automatic power recovery
• Turning the power on schedule
• Fan speed control
• D-Link Green Ethernet
• Supports connection to the UPS (via USB)
Remote file sharing
• File Web-server
• FTP-server
• WebDAV
• Access to your mobile device
• Access to the mydlink portal
File Sharing
• Max. number of user accounts: 256 people
• Max. the number of group accounts: 256 groups
• Max. the number of public folders, folder 128
• Max. Samba-concurrent connections: 64 connections
• Max. the number of simultaneous FTP-connections: 10 connections
נתונים פיזיים
Measurements
• 90 x 144,3 x 193,3 mm
Weight
• 113.4 g
Nutrition
• External power supply 12 V DC / 3 A
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 70 C
Humidity
• From 5% to 90% (non-condensing)
Certifications
• CE
• FCC
• IC
• DLNA
תקנים
הורדות
איורים
DNS-320L
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
