DSN-3200-10EOL EOS
תאור
The D-Link xStack Storage™ Area Network (SAN) Array DSN-3200-10 is designed to provide a reliable network data storage solution for customers in entry-level and SMB segments. Utilizing a 10Gbit iSCSI System-on-a-Chip (SoC) solution that can handle over 80,000 I/Os per second and capable of supporting 15TB raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced), the DSN-3200-10 Array can easily be implemented as nearline storage to supplement your primary IP network storage solution or be used as a basic backup and recovery device. This evolutionary advancement in performance is a testament to the tightly integrated xStack Storage architecture and is a sharp contrast to the discrete implementation of competing products.
Learn more. Download the D-Link xStack storage Whitepaper
iSCSI for IP Networks
SAN has been traditionally reserved for Fibre Channel networks until the recent introduction of iSCSI that extends this powerful yet simple centralized backend (behind server-based) storage system to IP networks. By utilizing existing Ethernet technology, the cost associated with separate host bus adapters and the per-Gigabyte cost for storage is significantly reduced.
High Performance iSCSI Interface
The DSN-3200-10 implements eight 1GbE ports and supports IEEE 802.3ad Link Aggregation Groups (LAG) for full offload capability so that all eight ports can be grouped together, totaling up to 850MB/s bandwidth, for increased throughput and redundancy.
System-on-a-Chip (SoC) Implementation
By utilizing a SoC design, the DSN-3200-10 SAN Array combines both networking and storage functions into a single specialized Application Specific Integrated Circuit (ASIC). The SoC solution combines 10Gbps iSCSI, TCP & IP offload, embedded processors, and a storage virtualization firmware stack onto a single chip. The tight integration of these functions eliminate interoperability, timing, and support issues found in competitive products that offer “discrete implementation” wherein a chassis, a main motherboard, a RAID storage controller, iSCSI software or controller, network interface cards, and operating system software are picked separately and then assembled. The DSN-3200-10 Array outperforms these discrete implementations and does so at a lower price point. It also delivers mission critical data quickly with state-of-the-art reliability.
RAID for Efficiency
The DSN-3200-10 SAN Array platform features 15 hot swappable Serial ATA (SATA) disk drive bays supporting 15TB raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced) in RAID level 0, 1, 1+0 and 5 configurations. You can quickly deploy a SAN using inexpensive SATA disk drives and depending on your growing storage needs, you can simply add more drives as you go.
Available Hard Drives (Hot Swap Tray is included)
DSN-111-400 400GB SATA HDD + Hot Swap Tray for DSN-3000 Series
DSN-111-500 500GB SATA HDD + Hot Swap Tray for DSN-3000 Series
DSN-111-750 750GB SATA HDD + Hot Swap Tray for DSN-3000 Series
Recommended hard drives for the DSN-3000 series SAN arrays:
To see a list of compatible drives, please see our Interoperability Matrix documentation (PDF).
Embedded Centralized Storage Management
The embedded user-friendly IP-SAN Device Manager (IDM) provides comprehensive storage network management. Boasting a rich set of management features, this suite of utilities allows monitoring and control of your SAN via the SMI-S (Storage Management Initiative) command set. Combined with an embedded secure server, users will be able to remotely configure and monitor their SAN storage subsystems.
Advanced Management Features
The DSN-3200-10 SAN Array provides additional advanced features for efficient management of network storage and optimal performance.
Cache Management: Provides adaptive and persistent cache management. This provides write-back, write-through, write coalescing and multi-stream read-ahead on a volume basis. This optimizes cache utilization and performance in an application dependent manner.
VLAN Zoning: Supports IEEE 802.1q VLAN tagging to segregate traffic into isolated zones for secure access and jumbo frames to improve the network throughput and reduce CPU overhead.
Volume Virtualization: The DSN-3200-10 SAN Array has a storage management software stack that provides volume virtualization features by utilizing the concept of storage Extents. Extents are the fundamental building blocks used to enable features such as RAID, online capacity expansion and volume migration. Drives of disimilar size can be used to create volumes. Growth can occur without volume migration or reconstruction. Single drives can contain multiple and divergent RAID technologies. Volume structure can also provide infrastructure for Snapshot copies.
RAID Support: RAID Levels 0, 1, 1+0 and 5 (striped sets, mirrored sets, striped mirrored sets, and parity sets).
Online Capacity Expansion and RAID Level Migration: Volumes can be expanded and/or migrated to other RAID levels while online with minimal impact on users. For example, a mirror volume of two drives can easily be converted to a parity volume of three or more drives while users continue to access this storage.
Micro Rebuilds: Provides protection against unresponsive SATA commands by forcing a response within a preset time limit.
Whether you are looking for a low-cost block-based solution for data backup and recovery, replacement of some of your inefficient Direct-Attached Storage (DAS) drives, or provide cost-effective centralized storage for your servers, the DSN-3200-10 SAN Array has a solution for you.
Works With:
SureSync Continuous Data Protection & Replication Software for xStack Storage
DSN-210-SW
מאפיינים כללים
