תכונות המוצר:
מערך אחסון iSCSI SAN מסדרת xStack, עד 15 דיסקים נשלפים SATA-II ויציאת 10Gb אחת לרשת |
תאור:
The D-Link xStack Storage™ Area Network (SAN) Array DSN-3400-10 is designed to provide a reliable network data storage solution for customers in entry-level and SMB segments. Utilizing a 10Gbit iSCSI System-on-a-Chip (SoC) solution that can handle over 80,000 I/Os per second and capable of supporting 15TB raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced), the DSN-3400-10 Array can easily be implemented as nearline storage to supplement your primary IP network storage solution or be used as a basic backup and recovery device. This evolutionary advancement in performance is a testament to the tightly integrated xStack Storage architecture and is a sharp contrast to the discrete implementation of competing products.
High Performance iSCSI Interface System-on-a-Chip (SoC) Implementation RAID for Efficiency Available Hard Drives (Hot Swap Tray is included) Recommended hard drives for the DSN-3000 series SAN arrays: Embedded Centralized Storage Management Advanced Management Features Cache Management: Provides adaptive and persistent cache management. This provides write-back, write-through, write coalescing and multi-stream read-ahead on a volume basis. This optimizes cache utilization and performance in an application dependent manner. VLAN Zoning: Supports IEEE 802.1q VLAN tagging to segregate traffic into isolated zones for secure access and jumbo frames to improve the network throughput and reduce CPU overhead. Volume Virtualization: The DSN-3400-10 SAN Array has a storage management software stack that provides volume virtualization features by utilizing the concept of storage Extents. Extents are the fundamental building blocks used to enable features such as RAID, online capacity expansion and volume migration. Drives of disimilar size can be used to create volumes. Growth can occur without volume migration or reconstruction. Single drives can contain multiple and divergent RAID technologies. Volume structure can also provide infrastructure for Snapshot copies. RAID Support: RAID Levels 0, 1, 1+0 and 5 (striped sets, mirrored sets, striped mirrored sets, and parity sets). Online Capacity Expansion and RAID Level Migration: Volumes can be expanded and/or migrated to other RAID levels while online with minimal impact on users. For example, a mirror volume of two drives can easily be converted to a parity volume of three or more drives while users continue to access this storage. Micro Rebuilds: Provides protection against unresponsive SATA commands by forcing a response within a preset time limit. Whether you are looking for a low-cost block-based solution for data backup and recovery, replacement of some of your inefficient Direct-Attached Storage (DAS) drives, or provide cost-effective centralized storage for your servers, the DSN-3400-10 SAN Array has a solution for you |
ראה גם
