DSN-2100-10EOL EOS
מערך אחסון iSCSI SAN מסדרת xStack, עד 8 דיסקים נשלפים SATA-II ו- 4 יציאות ג'יגהביט לרשת
היכן לקנות
תאור
The D-Link DSN-2100-10 xStack Storage Area Network (SAN) Array is designed to provide a smaller, more value oriented solution for entry-level and SMB customers. The heart of the DSN-2100-10 SAN Array is based on the same powerful System-on-a-Chip (SoC) design found in larger arrays such as the DSN-3000 series of products, but housed in a smaller chassis. Utilizing a 10Gbit iSCSI SoC solution that can handle over 80,000 I/Os per second and capable of supporting 8TBs of raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced), the DSN-2100-10 SAN Array can easily be implemented as nearline storage or as a supplement to your primary backup and recovery device. This evolutionary advancement in performance is a testament to the tightly integrated xStack Storage architecture and is a sharp contrast to the discrete implementation of competing products.
Learn more. Download the D-Link xStack storage Whitepaper
iSCSI for IP Networks
SAN has been traditionally reserved for Fibre Channel networks until the recent introduction of iSCSI that extends this powerful yet simple centralized backend storage system to IP networks. By utilizing existing Ethernet technology, the cost associated with separate host bus adapters and the per-Gigabyte cost for storage is significantly reduced. iSCSI SANs can leverage the Ethernet infrastructure and standards which are quite familiar to your IT staff.
Check out the product video in D-LinkTV
Four 1GbE Interfaces
The DSN-2100-10 SAN Array implements four 1GbE ports and supports IEEE 802.3ad Link Aggregation Groups (LAG) for full offload capability so that all four ports can be grouped together, totaling up to 425MB/s bandwidth, for increased throughput and redundancy.
Click to enlarge
System-on-a-Chip (SoC) Implementation
By utilizing a SoC design, the DSN-2100-10 SAN Array combines both networking and storage functions into a single specialized Application Specific Integrated Circuit (ASIC). The SoC solution combines 10Gbps iSCSI, TCP & IP offload, embedded processors, and storage virtualization firmware onto a single chip. The tight integration of these functions eliminate interoperability, timing, and support issues found in competitive products that offer “discrete implementation” wherein a chassis, a main motherboard, a RAID storage controller, iSCSI software or controller, network interface cards, and operating system software are chosen separately and then assembled. The DSN-2100-10 SAN Array outperforms these discrete implementations and does so at a lower price point. It also delivers mission critical data quickly with state-of-the-art reliability.
RAID for Efficiency
The DSN-2100-10 SAN Array platform features 8 hot swappable Serial ATA (SATA) disk drive bays supporting 8TB raw capacity using 1TB hard drives (and even higher capacity hard drives as they are introduced) in RAID level 0, 1, 1+0 and 5 configurations. You can quickly deploy a SAN using inexpensive SATA disk drives and, depending on your growing storage needs, you can simply add more drives as you go.
Recommended hard drives for the DSN-2000 series SAN arrays:
To see a list of compatible drives, please see our Interoperability Matrix documentation (PDF).
Embedded Centralized Storage Management
The embedded user-friendly IP-SAN Device Manager (IDM) provides comprehensive storage network management. Boasting a rich set of management features, this suite of utilities allow monitoring and control of your SAN via the SMI-S (Storage Management Initiative Specification) command set. Combined with an embedded secure server, users will be able to remotely configure and monitor their SAN storage subsystems.
Advanced Management Features
The DSN-2100-10 SAN Array provides additional advanced features for efficient management of network storage and optimal performance.
Cache Management: Provides adaptive and persistent cache management. This provides write-back, write-through, write coalescing, and multi-stream read-ahead on a volume basis. This optimizes cache utilization and performance in an application dependent manner.
VLAN Zoning: Supports IEEE 802.1q VLAN tagging to segregate traffic into isolated zones for secure access and jumbo frames to improve the network throughput and reduce CPU overhead.
Volume Virtualization: The DSN-2100-10 has storage management software that provides volume virtualization features by utilizing the concept of storage Extents. Extents are the fundamental building blocks used to enable features such as RAID, online capacity expansion and volume migration. Drives of disimilar size can be used to create volumes. Growth can occur without volume migration or reconstruction. Single drives can contain multiple and divergent RAID technologies. Volume structure can also provide infrastructure for Snapshot copies.
RAID Support: RAID Levels 0, 1, 1+0 and 5 (striped sets, mirrored sets, striped mirrored sets, and parity sets) are supported, allowing different storage options.
Online Capacity Expansion and RAID Level Migration:: Volumes can be expanded and/or migrated to other RAID levels while online and with minimal impact on users. For example, a mirror volume of two drives can easily be converted to a parity volume of three or more drives while users continue to access this storage.
Micro Rebuilds: Provides protection against unresponsive SATA commands by forcing a response within a preset time limit.
An iSSCSI array can prove to be a valuable tool to supplement your network storage foundation. Whether providing a low- cost block-based solution for data backup and recovery, replacement of Direct-Attached Storage (DAS) drives, or providing a cost-effective entry-level nearline storage solution, the DSN-2100-10 xStack Storage Area Network (SAN) Array can meet your immediate needs.
Works With:
SureSync Continuous Data Protection & Replication Software for xStack Storage
DSN-210-SW
xStack 48-Port Layer 2 Gigabit Switch
DXS-3250
מאפיינים כללים
Drive Bays
8
Drive Interface Support
SATA-II support
System Memory
256MB to 512MB (512MB standard)
Cache Memory
256MB to 4GB (512MB standard)
Battery Backup for Cache
Standard (approximately 72 hours on full charge)
Bandwidth
Up to 425MB/s
Storage Capacity
8TB capacity with 1TB hard drives (supports for higher capacity drives as they are introduced)
Operating Systems Supported
Windows® Vista® 32-bit & x64 (Ultimate & Enterprise) with Built-in iSCSI initiator
Windows Server 2003® 32-bit & x64 SP1 (Standard & Enterprise) with v2.04 iSCSI initiator
Windows Server 2003 R2 32-bit & x64 (Standard & Enterprise) with v2.04 iSCSI initiator
Windows XP Pro 32-bit & x64 with v2.04 iSCSI initiator
Windows 2000 Advanced Server with v1.6 & v2.01 iSCSI initiator
Fedora® Core® 6 & 7
Red Hat® 7.3
Red Hat 9
Red Hat Enterprise® WS 3 update 4
Red Hat Enterprise ES 4 update 4 & 5 32-bit & x64
Red Hat Enterprise AS update 4
SuSE® Professional 9.3 32-bit & x64
OS® X (10.4.7 | 10.4.8 | 10.4.10)with Intel® and Power PC CPUs
Supported NICs, iSCSI Accelerators and iSCSI HBAs
Intel® Pro 1000MT & XT [1GbE]
Intel Pro 10000 CX4 [10GbE]
Chelsio® S210X-SR-XFP (S2iO) [10GbE]
Neterion® Xframe® II & Xframe E [10GbE]
Alacritech® SES2104ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
Alacritech SES2102ET (drivers: SNP 9.1.0.1092 & 7.3.1.0)
QLogic® 4010C
QLogic 4052C
iSCSI Network Interface
Four (4) 1GbE Copper Ports
Host Interface
iSCSI Draft 20 compliant initiator
Connections
1,024 hosts
CHAP Authentication
Yes
Access Control of Management
Yes
iSCSI/TCP/IP Full HW Offload
Yes
Jumbo Frames Support
Yes
LAG Support (Link Aggregation)
Yes – Up to four (4) LAGs (IEEE802.3ad Link Aggregation Group)
VLAN Support
Up to eight (8). 1-to-1 mapping between IP subnet and VLAN. Multiple VLANs per physical port with VLAN tag. All physical ports in LAG belong to same VLAN (IEEE802.1Q Tag)
Volume & RAID Support
RAID Controller
Single- Integrated in ASIC
RAID Support
Volumes
1,024 Virtual Volumes (256 accessible per initiator)
Target Nodes
1,024
Yes
Hot Swappable Drives
Yes
Instant Volume Access
Yes
Free Space Defragmentation
Yes
Auto-Detection Failed Drive
Yes
Auto-Rebuild Spare Drive
Yes
Yes
Drive Roaming in Power Off
(configured drives are not bay-specific)
Yes
Micro Rebuilds
Yes
Storage Management
Embedded IP-Based Management GUI
Create, manage, expand and monitor storage pool, volumes and RAID
Event manager to view and persist events
Firmware Field Upgradeable
Yes
SMI-S Version 1.1
Yes
Power
Supply Type
Redundant 2U 400 Watt
Input Voltage
100-240 VAC
Input Frequency
47-63 Hz
Input Current
8A Maximum at 100VAC and 4A Maximum at 240VAC
(maximum amps vs. voltage varies linearly throughout this voltage range)
Power Factor Correction
95%@110V, Full load
Power Consumption
360W (full configuration)
Thermal
1260 BTU / hour (full configuration)
Environmental
Operating Temperature
32° to 104°F (0° to 40°C)
Storage Temperature
-4° to 158°F (-20° to 70°C)
Operating Humidity
20% ~ 90% (Non-condensing)
Storage Humidity
10% ~ 95% (Non-condensing)
Physical (approximate)
Form Factor
2U industry-standard 19-inch rack
Dimesnsions (D x W x H)
25in x 17.25in x 3.5in (63.5cm x 43.8cm x 8.9cm)
18.75in (47.6cm) wide at the mounting brackets
Weight
45 lbs / 20.4 Kg (full configuration)
International Approvals
Emissions
CE Class A, FCC Class A, C-Tick Class A, VCCI Class A
Safety
CSA 60950-1, UL60950-1, IEC 60950-1, EN 60950-1
Warranty and Support
Warranty
2-Year Limited* (manufacturer’s warranty on hard drives)
Extended Warranty
Available
Support
1 year, 9 hours per day / 5 days per week Technical Support
Available Configurations
DSN-2100-10
xStack 4x1GbE iSCSI SAN Array, 8 Bays, 2U, w/o Drives, with Trays
נתונים פיזיים
תקנים
הורדות
איורים
DSN-2100-10
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
