DCS-5222LEOL EOS
מצלמת מעקב אלחוטית בתקן 802.11n באיכות HD עם מנוע מכני
היכן לקנות
תאור
Multi-camera for video surveillance
Wireless 802.11n HD video camera with tilt and rotate the drive D-Link DCS-5222L is the ideal solution for small and medium-sized businesses, as well as remote monitoring via the Internet. DCS-5222L provides detailed clock remote monitoring of a vast territory, using the HD megapixel sensor for high-quality high-definition video and built-in infrared illuminator for video surveillance in low light conditions. DCS-5222L can also connect to a wireless network that allows you to place the camera anywhere without the need for network cables.
A powerful video surveillance system
DCS-5222L provides embedded processor that allows you to use the camera as a standalone security system. Recording can be done continuously, by motion or in accordance with the established schedule. In the case of certain events, you can send e-mail notification, which allows the user to be aware of what is happening. Built-in microSD card slot allows the camera to work regardless of network connection or can be used for continuous video recording, even if the network connection is lost. DCS-5222L can also be used as part of a video surveillance system built from multiple cameras via the supplied software D-ViewCam, which supports up to 32 cameras.
A clear picture from different angles
With features pan / tilt and digital zoom IP-camera DCS-5222L provides an overview of a large area from different angles and 4x digital zoom for detail izobrazheniya.1 You can also configure automatic movement of IP-camera DCS-5222L between predetermined positions, which allows patrol a large territory.
Utility mydlink ™ for easy installation and remote viewing on your phone
A convenient utility mydlink ™ can be quickly set up IP-camera DCS-5222L, and then register it on the Web-site mydlink ™. DCS-5222L will automatically configure and connect to the service mydlink ™, which will provide easy access to video over the Web-site mydlink ™. The image from the camera can be viewed even on a smartphone or tablet PC with iOS and Android, so staying in touch constantly.
מאפיינים כללים
Camera Specifications
• 1/4-inch megapixel CMOS-sensor with progressive scan technology
• Infrared light: the range of illumination - 5m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• Built-in PIR
• Fixed lens with a focal length of 4.57 mm
• The aperture of F1.9
• Angle:
  - 45.7 a (horizontal)
  - 29.5 a (vertical)
  - 52.9 a (diagonal)
• Built-in microphone / speaker
Functional videos
• Setting quality and image size, frame rate and data rate
• Timestamps and paste text
• Customizable windows for motion detection
• Setting the shutter speed, brightness, color saturation, contrast, mirroring, and the coup
• 3 customizable private area masks
Video Compression
• JPEG for still images
• Compression formats H.264/MPEG4/MJPEG
• H.264/MPEG4 multicast streaming
Video Resolution
• 16:9 (transmission speed up to 30 frames / s)
• 1280 x 720
• 640 x 352
• 320 x 176
• 160 x 80
Pan / Tilt / Zoom
• The angle of rotation from 170o to 170o-
• The angle of inclination from 25 ° to 90 °-
• Digital Zoom: 4x1
• Manual swing speed: 1-10
• Manual tilt speed: 1-10
• The parameters preset: 10 points
Audio Compression
ADPCM, PCM
Network Protocol Support
IPv4, ARP, TCP, UDP, ICMP, DHCP-Client, NTP-client (D-Link), DNS-Client, DDNS-client (D-Link), SMTP-client, FTP-client, HTTP-server, PPPoE, RTP, RTSP, RTCP, 3GPP
Remote management
• Setting up a Web-browser
• Obtaining and maintaining stop-kadrov/videoklipov on the local hard drive via Web-browser
Security
• Protection of the Administrator account and user group
• Authentication by password
• Digital encryption, HTTP and RTSP
Surveillance
• Continuous video recording
• Record video in a weekly schedule
• Records video when motion is detected
• Download stop-kadrov/videoklipov via e-mail
• Downloading via FTP stop-kadrov/videoklipov
Network Interface
IEEE 802.11n
System Requirements
• Operating System: Microsoft Windows 7/Vista/XP SP3
• Browser: Internet Explorer 6 or higher, Firefox 3.5, Safari 4.0
Supported Mobile
• Mobile devices with 3GPP-player, such as Packet Video Player 3.0, Quick Time 6.5 or Real Player 10.5
• Appendix mydlink ™ requires a mobile device with iOS or Android
נתונים פיזיים
Input voltage
• 12 V / 1,25 A, 50/60 Hz
Power consumption
• 10.5 W (max)
Dimensions
• 114 x 114 x 125 mm
Weight
• 540 g
Operating temperature
• From 0 to 40 ° C
Storage temperature
• From -20 To 70 C
Humidity
• From 20% to 80% (no condensation)
Certificates
• FCC Class B
• CE
• CE LVD
• C-Tick
Delivery
• Camera DCS-5222L
• External power adapter
• Ethernet-cable category 5
• Quick Installation Guide
• Remote Control
• CD-ROM with Installation Wizard
• Support for the camera and mounting kit
תקנים
הורדות
איורים
דף מידע
ראה גם
