DIB-200
מתאם Stream TV
היכן לקנות
תאור
Adapter StreamTV DIB-200 - a compact device that allows you to view media content on a high definition big screen. With this adapter, you can watch HD-video display or projector, displaying media content from the Internet to the TV, or play music library without the use of wire communication.
Full HD support, and other features
Powerful processor adapter DIB-200 is able to decode high-definition video at resolutions up to 1080p, delivering a crisp, highly detailed HD-image to any compatible display. DIB-200 supports popular video formats H.264, MPEG4 and WMV, as well as the image format JPEG, allowing you to view movies or photos on the big screen with high detail. The adapter also supports audio formats MP3 and WMA, allowing you to connect your TV to the audio system for listening to digital music library.
Freedom of movement provided by the wireless network
StreamTV adapter uses a high-speed wireless technology for streaming media content from the device to the big screen. This eliminates the need for cables and provides the ability to control the playback of video and music from your couch or moving the device around the house. Small form factor devices can arrange viewing media content on HDMI-display anywhere. All that is required - is the presence of the display and network Wi-Fi.
Simple streaming using DLNA-applications
All that is required - is a mobile device and one of the many applications that allow streaming media content to DLNA-devices. Use this application to play your music collection or media content from the Internet on your TV. The adapter sends StreamTV streaming media content from the device through a wireless router, during playback of content can be minimized application and return to the use of mobile devices in the usual way, ie browse Web-sites, check e-mail and play games.
Quick and easy
Setting DIB-200 performs a few simple steps thanks to an intuitive interface for mobile devices. When done, connect the adapter to your wireless network, open a DLNA-application and start viewing content. The new devices connected to the network Wi-Fi, will automatically detect the adapter StreamTV and prepared for use, there is no need to connect each device individually.
מאפיינים כללים
Device Interfaces
• IEEE 802.11n/g/b
• HDMI (Type A)
• Micro USB (for power input)
Standards
• DLNA
• IEEE 802.11b
• IEEE 802.11g
• IEEE 802.11n
• HDMI
• Wi-Fi Miracast1
Minimum requirements
• TV, monitor or other display with an HDMI type A
• Mobile device with iOS or Android2
Supported formas
• Video: H.264, MPEG4, WMV
• Audio: MP3, WMA, AC3
• Picture: JPEG
נתונים פיזיים
Measurements
• 60 x 37 x 14 mm
Weight
• 20 g
Power
• Input: 2.5 W via USB
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 65 C
Humidity
• Operating: 0% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• DLNA
• CE
• Certified WiFi4
• FCC
תקנים
הורדות
איורים
DIB-200/Bx
מראה מקדימה
דף מידע
ראה גם
