חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת מגה-פיקסל לשימוש ביתי או למשרד הקטן
דגם לא מיוצר יותר
מאפיינים כללים:
Specifications:
·         Support OS
·         Device
·         Windows 2000 / Windows XP / Windows Vista / 3GPP
   Utility
Network Protocols
·         IPV4, ARP, TCP, UDP, ICMP
·         DHCP Client
·         DNS Client
·         SMTP Client
·         HTTP Server
·         PPPoE
·         RTSP
·         3GPP
·         NTP Client
·         DDNS Client
·         FTP Client
·         Samba Client
·         RTP
·         RTCP
LAN
·         Port 10/100BASE-TX
·         Compatible with IEEE 802.3
·         Compatible with IEEE 802.3u
·         Supports full duplex mode
·         Auto-polarity of MDI / MDIX
·         Flow control is at full duplex mode, 802.3x
Support for video compression algorithms
·         MPEG-4/MJPEG
Support for audio compression algorithms
·         GSM-AMR: 8kbps,
·         ADPCM: 8Kbps
Sensor
·         ¼ inch CMOS-sensor with a resolution of 1.3 lm
Memory SDRAM
·         64 MB
Flash-memory
·         8 MB
Slot SD-CARD
·         Supports cards up to 16 GB
Lens
·         Focal length: 5.01 mm, F2.8
Microphone
·         50dB + / - 3dB, omnidirectional
Additional inputs / outputs
·         1 alarm relay output (max. DC 24V/1A, 125V AC / 0,5 A)
·         1 optically isolated sensor input (max. DC 12V/50mA)
Audio
·         Yes
Reset Button
·         Return to factory default settings
·         Simultaneous compression format in MPEG-4/MJPEG
JPEG frame for shooting
Internet Video
·         Adjustable image size and quality
·         Imposition of provisional marks, and text
Rotation and mirroring
Video
·         VGA (640 X 480)
·         640 x 480 up to 30 frames / s.
·         320 x 240 up to 30 frames / s.
·         160 x 120 up to 30 frames / s.
·         XGA (1024 X 768)
·         1024 x 768 up to 10 frames / s.
·         512 x 384 up to 10 frames / s.
·         256 x 192 up to 10 frames / s.
·         SXGA (1280 x 1024)
·         1280 x 1024 up to 10 frames / s.
LUX
·         0.5 lux@F2.8
·         3A CONTROL
·         AGC (Automatic gain of the video)
·         AWB (Auto White Balance)
·         AES (automatic electronic shutter)
Frequency
·         50 ~ 16000 Hz
The ratio of signal to noise ratio
The physical and climatic conditions
·         Dining
Power Adapter 5V 2.5A
·         External power supply
Maximum power consumption
·         6 W
·         At the entrance: 100-240 VAC, 50/60 Hz
·         The output: 5 VDC, 2.5A
Dimensions (ShxDxV)
·         71.9 mm x 110.0 mm x 37 mm (without the bracket and rack)
Weight
·         265.3 g (without the bracket and rack)
Operating temperature
·         From 0 ˚ to 40 ˚ C
Storage Temperature
·         From - 20 ˚ to 70 ˚ C
Humidity
·         From 20 to 80% non-condensing
Emission (EMI), security certificates and other
·         FCC Class B
·         IC
·         C-Tick
·         CE
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
