תאור
POWERFUL 24 HOUR SURVEILLANCE
D-Link’s DCS-6410 Day & Night PoE Dome Network Camera is designed for round-the-clock surveillance. A CCD (Charged-coupled Device) sensor delivers high-quality images without distortion, while mounted infrared LEDs allow for nighttime monitoring over distances of up to 49 feet (15 meters). These elements make the DCS-6410 an ideal camera for indoor surveillance applications in homes, offices and business facilities.
The DCS-6410 supports simultaneous dual-streaming for live monitoring and recording, and delivers excellent video quality. Embedded with a powerful SoC (System-on-Chip), the camera provides high-quality, real-time video compression in MPEG-4 and motion JPEG formats. D-ViewCam, the free, bundled software capable of recording and displaying 32 channels allows you to reliably monitor and record high-quality images. Leverage the camera’s built-in Samba client to directly transfer images and videos to a NAS without the need for any additional hardware or software.
CLEAR, SHARP IMAGES FROM EVERY ANGLE
The dome-shaped DCS-6410 provides for greater viewing angles making it
ideal for monitoring narrow spaces like elevators. The camera is
capable of recording in MPEG-4 and motion JPEG compression with
D1/CIF/QCIF resolution for smoother performance. Images are delivered
at a maximum resolution of D1 at up to 30 frames per second.
SURVEILLANCE ON THE GO
The DCS-6410 supports 3GPP mobile surveillance. A live feed from the
camera can be accessed on a 3G cellular network using a compatible cell
phone, PDA or any device capable of RTSP (Real Time Streaming Protocol)
streaming. This enables you to monitor your home or offi ce space in
real time even when you are on the go.
Power over Ethernet (PoE) connectivity allows for discreet installation in virtually any indoor location. For effective surveillance around any space, this camera’s built-in 802.3af compliant PoE module eases the installation process by reducing the need to lay additional cabling. In addition, the 10/100BASE-TX Ethernet port connects seamlessly to local network or to the Internet via a gateway router. The camera can be accessed and viewed from any network place as a device on the network. The DCS-6410 also features an RCA connector which can be integrated easily into your existing analog CCTV (Closed Circuit Television) system; helping you migrate from an existing analog security system to an IP-based solution.
EASY TO INSTALL AND EASIER TO MANAGE
The DCS-6410 can be mounted on a fl at surface or with a drop-ceiling
bracket. Manage and monitor upto 32 cameras using D-Link’s D-ViewCam
software. You can also set up automated e-mail alerts to be instantly
informed of unusual activities. In addition, this network camera
supports the Universal Plug-n-Play feature, which allows computers
running on Windows XP/Vista to automatically recognize the camera and
adds it to the network. Sign up with one of the free Dynamic DNS
services available on the web, to assign a name and domain to the
camera (for example, mycamera.dlinkddns.com). This allows you to
remotely access the camera without having to remember the IP address.
