חיפוש מהיר
תכונות המוצר:
מצלמת מעקב מגה-פיקסל עם חיישן WDR ואפשרות צילום לילי
דגם לא מיוצר יותר
מאפיינים כללים:
Key Features
• Progressive Scan, 1/3-inch CMOS-sensor
• Removable IR-cut filter:
• Auto / Schedule / Manual
• 3A Control: AGC, AWB, AES
• varifocal lens 2.8-12mm, F1.3 *
• varifocal lens 2.9-8mm, F1.3 **
• Minimum illumination: 0.3 lux, B / W: 0,02 lux
• WDR SN ratio: 100dB
Audio
• 2-way audio transmission
• The external audio input
• External Audio
• Codec G.726
Video compression
• Simultaneous compression in MPEG and MJPEG
• Simultaneous compression formats h.264 **
• Support for profiles through the web-based interface, viewing video on 3G mobile phone and video recording
Video Resolution
• Supported Resolutions: 1280 x 960/1280 x 720/640 480/320 x 240/160 x 120
• Up to 30 frames per second for all resolutions
Network connection
• 802.3af Power over Ethernet (PoE)
• Auto-negotiation 10/100 Mb / s Fast Ethernet
Connector I / O
• Lens with Auto Iris, 4-pin connector
• DI x 2
• DO x 1
• RS-485
• 12 VDC, 200 mA output
• Slot for SD-Card
Security
• Protection of the Administrator and User Groups
• Authentication by password
Remote management
• Camera confiscation, and the camera system log
• To capture a Web-browser and save to your hard drive
Network protocols
• IPv4, DHCP, ARP, DNS, TCP / IP, DDNS (D-Link), HTTP, port forwarding UPnPTM
• Samba, SMTP, PPPoE, NTP (D-Link), FTP, RTP, RTSP, UDP, RTCP, ICMP, 3GPP
System requirements for viewing
• Internet Explorer 6.0 or higher
System requirements to run for the D-Viewcam
• Operating system: Windows Vista, Microsoft Windows XP
• Web-browser: Internet Explorer 6.0 or higher
• Protocol: TCP / IP
נתונים פיזיים
Input voltage
• 100-240 VAC, 50/60 Hz, 12 V DC, 1.25 A
Dimensions
• 88 x 53 x 194 mm
Operating temperature
• From 0 ˚ to 40 ˚ C
Storage temperature
• From -20 ˚ to 70 ˚ C
Humidity
• 20% - 80% (no condensation)
Certificates
• CE (Class A)
• On-Tick (Class A)
• FCC (Class A)
* Only for DCS-3710
** Only for DCS-3710/B1A
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
