DCS-5230LEOL EOS
תאור
Full-featured wireless surveillance camera
D-Link DCS-5230L Pan & Tilt Wireless N Network Camera is a pan and tilt wireless network camera, ideal for small-to-medium business applications and remote monitoring over the Internet. It gives you detailed remote surveillance of a large area by using a 1.3 megapixel CMOS image sensor for high-quality video and a built-in IR illuminator for low-light surveillance. The DCS-5230L can also be connected to your network wirelessly, allowing you to place the camera anywhere, and eliminating the need to install network cabling.
A complete surveillance system
The DCS-5230L includes a built-in CPU, allowing it to be used as a complete, standalone surveillance system. Recordings can be made continuously, whenever movement is detected, or according to a schedule you define. E-mail notifications can be sent when specific events occur, keeping you informed of what’s going on. The built-in microSD slot allows the camera to run independently, or can be used to continuously record video even if the network connection is lost. The DCS-5230L can also be used as part of a multi-camera surveillance system through the included D-ViewCam software, which supports up to 32 cameras.
Sharp image monitoring from different angles
With sharp, responsive pan/tilt movement and digital zoom, the D-Link Pan & Tilt Wireless N Network Camera gives you full control, so you can quickly scan a wide area from a variety of angles, and 16x digital zoom lets you zoom in for more detail.1 The DCS-5320L can also be set to automatically move to specific preset positions, allowing the camera to patrol and secure a wide area.
MyDLink for easy setup and remote viewing on your phone
D-Link’s convenient mydlink™ zero-configuration setup gets you up and running in no time – just connect the DCS-5320L, then register the device on the mydlink™ website. The DCS-5320L will then automatically configure itself and connect to the mydlink™ service, which gives you convenient access to your video feeds through the mydlink website. You can even view your camera feeds on your smart phone or tablet with the mydlink iOS and Android apps so you can stay in touch on the go.
מאפיינים כללים
Network Protocols
IPv4, ARP, TCP, UDP, ICMP, DHCP-client, NTP-client (D-Link), DNS-client, DDNS-client (D-Link), SMTP-client, FTP-client, HTTP-server, Samba- client, PPPoE, RTP, RTSP, RTCP, 3GPP
Built-in network interfaces
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.11b
• 10/100BASE-TX Fast Ethernet supports auto-sensing MDI / MDIX
Support for compression algorithms
• Saving still images in JPEG format
• Video compression using MPEG4
• Compression formats: MPEG / MJPEG
Video resolution
VGA (640 x 480)
• 640 x 480: up to 30 frames / s
• 320 x 240: up to 30 frames / s
• 160 x 120: up to 30 frames / s
XGA (1024 x 768)
• 1024 x 768: up to 10 frames / s
• 512 x 384: up to 10 frames / s
• 256 x 192: up to 10 frames / s
SXGA (1280 x 1024)
• 1280 x 1024: 10 frames / s
Functional video
• Setting the picture quality and size
• Timestamps and paste text
• Three windows to configure the motion detection
• Flip & mirror
Speed transmission of video
20 Kbit / s - 4 Mbit / s
Сharacterization of camera
• Built-in 1/3-inch CMOS-sensor
• Standard lens, 3.98 mm, F2.0
• AGC / AWB / AES
• Electronic shutter: 1 / 60 to 1 / 15000 sec
• Angle of View 62 °
Pan / Tilt / Zoom
• Angle: 130 ° ~ -180 °
• Tilt: +5 ° ~ -45 °
• Digital Zoom: 16x
Audio
Compression and transmission rate GSM-AMR: 12,20 kbit / s, PCM: 8 kbit / s
Microphone
• Directivity: omnidirectional
• Frequency range: 20 ~ 20,000 Hz
• S / N Ratio: 58dB more
Security
• Protection of the Administrator account and user group
• Password authentication
• Wireless Network Security: 64/128-bit WEP and WPA-PSK encryption
Monitoring functions
• Remote management / control of up to 16 cameras
• Viewing images from 32 cameras on one screen
• Supports management via Web-based interface
• recording options for triggering a sensor or manually
Remote management
• Setting up a Web-browser
• Support Portal mydlink
• Getting pictures / videos via Web-browser and save to your local hard drive
Observation
(Motion detection on a weekly schedule)
• Downloading still images via e-mail
• Downloading still images / video clips via FTP
System Requirements
• Operating System: Microsoft Windows XP, 2000 / Vista / Linux / MAC OC X10.3 or higher
• Browser: Internet Explorer v6.0 or higher
Supported PDA, mobile phones and software
• Mobile phone with 3GPP-player
• Packet Video Player 3.0
• QuickTime 6.5
• Real Player 10.5
• Windows 2000, XP, Vista
Wireless LAN WLAN
Modulation schemes
• 802.11b: DQPSK, DBPSK and CCK
• 802.11g: BPSK, QPSK, 16QAM, 64QAM, OFDM
Operating frequency
2400 - 24 835 MHz
Speed wireless data transmission
• IEEE 802.11n: up to 300 MB / s
• 802.11b: 11, 5.5, 2 and 1 Mb / s
• 802.11g: 54, 48, 36, 24, 18, 12, 9 and 6 MB / s
Receiver Sensitivity
802.11b:
• 11 MB / s (CCK):-84dBm
• 5,5 MB / s (CCK):-86dBm
• 2 MB / s (DQPSK):-88dBm
• 1 MB / s (DBPSK):-90dBm
• (Normal @ PER <8% packet size 1024 @ 25 ° C + / - 5 ° C)
802.11g:
• 54 MB / s (OFDM):-66dBm
• 48 MB / s (OFDM):-70dBm
• 36 MB / s (OFDM):-76dBm
• 24 MB / s (OFDM):-79dBm
• 18 MB / s (OFDM):-83dBm
• 12 MB / s (OFDM):-85dBm
• 9 MB / s (OFDM):-86dBm
• 6 MB / s (OFDM):-86dBm
• (Normal @ PER <10% packet size 1024 @ 25 ° C + / - 5 ° C)
Transmitter output power
• 802.11n: 12dBm (typical)
• 802.11g: 12dBm (typical)
• 802.11b: 16dBm (typical)
Antennas
• 2 detachable dipole antenna with a gain of 2 dBi reverse SMA connector and
• Operating Frequency: 2.4 GHz
Delivery
• Camera DCS-5230L
• No external power adapter
• Ethernet-cable kat.5
• Quick Installation Guide
• Master on CD-ROM
• Dipole antenna
• Support for the camera
