חיפוש מהיר
תכונות המוצר:
מצלמת מעקב חיצונית עם אפשרות צילום לילי באיכות Full HD
תאור:
Full HD camcorder with the ability to night mode for outdoor use D-Link DCS-7413 is an ideal solution for creating a system of professional high-definition video, and security for small, medium and large enterprises. Highly sensitive two-megapixel CMOS-sensor with progressive scan technology provides excellent image quality in various lighting conditions. The compact design, "all in one" makes the camera ideal for safe installation and requires no additional accessories.
High-quality video
To maximize bandwidth efficiency and improve image quality, DCS-7413 compresses video in real time, using the MPEG-4 and MJPEG, and H.264, which creates a small file size and makes it suitable for long-term recording high detail or for use in networks with low bandwidth. In addition, DCS-7413 supports three separate profiles for simultaneous transmission of video in real time and record. This property provides a wide range of cameras for security purposes, such as monitoring of public places to detect incidents and coordinate the response, control of restricted areas, deterring criminal activities or monitoring of assets. In addition, the bandwidth requirements can be adjusted in real time over the network, and the recorded video files can be saved to a Network Attached Storage (NAS) or on a SD.
Continuous monitoring
Built-in infrared LEDs automatically according to the lighting conditions, allowing the camera to record videos even in low light or darkness. This function enables the camera to record a clear color image during daytime and black and white in low light conditions. DCS-7413 can detect moving objects in total darkness at a distance of 30 meters. Equipped with a powerful integrated circuit, the camera compresses video in real-time formats, H.264, MPEG-4 and MJPEG. The totality of these elements makes the DCS-7413 an ideal solution for day surveillance.
Reliable management software
With the camera DCS-7413 includes software D-ViewCam - ready set of software for video, allowing you to view, manage and record up to 32 cameras on a single computer. Video recording and email alerts can be started by motion or by triggering event with digital input devices to inform administrators of unusual activity.
Connectivity
The DCS-7413 is equipped with built-in PoE standard 802.3af, simplifies installation by providing power and network connectivity, one Ethernet-cable, and thus eliminates the need for drilling and routing the additional power cables. In addition, the digital input and output allow you to connect external devices such as IR sensors, switches and signal relay
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
