חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת חיצונית באיכות HD עם תמיכה ב PoE ועם חיבוריות ל mydlink
תאור:
HD IP-Camera Cube DCS-2310L with PoE and mydlink cloud service is designed to provide day and night outdoor surveillance.
24/7 Camera Surveillance
DCS-2310L has a megapixel sensor and allows you to create clear and detailed still images and videos in HD-quality with a resolution of up to 720p. Function application ePTZ, you can zoom, rotate an image with the camera, which in turn provides an overview of a large area.
Built-in ICR-filter during the day does not pass infrared light, which contributes to a high quality image. At night, the ICR-filter is moved to the side to use a wider range of radiation surveillance in low light conditions, and with infrared illumination allows monitoring even in complete darkness.
Outdoor surveillance
DCS-2310L is designed to provide outdoor surveillance and executed in weatherproof housing with protection from moisture and dust IP-65. Support PoE technology allows the simultaneous transmission of data and power over a single cable, which simplifies installation and enables the camera in places where the power supply is not available.
Access from anywhere with cloud services mydlink
External HD IP-Camera Cube supports cloud service mydlink, which gives the user the ability to remotely access the settings and images from IP cameras, regardless of its location. The user can view video from IP-camera to Web-site mydlink from any computer or mobile device with an iOS or Android, you can download special mobile app mydlink.
Automatic adjustment Zero Configuration
When a router with support for cloud service mydlink configure the network camera does not pose any difficulty due to the automatic adjustment Zero Configuration. To do this, simply connect the power adapter to the camera and the camera to a router with an Ethernet-cable, and the device will automatically be added to your account. Mydlink service allows even the most inexperienced user to quickly and easily configure the camera that supports the cloud.
Comprehensive features
With an extended functional DCS-2310L is ideal for various tasks surveillance. Infrared motion sensor (PIR) is designed to detect motion, which allows the camera to automatically take pictures and send you alerts when motion is detected. Built-in microphone and speaker provide two-way audio transmission, which is especially useful for conducting surveillance at the entrance to the building.
Ready scalable solution
DCS-2310L is a standalone solution for conducting surveillance and supports video recording and save still images to MicroSD card without the need for a PC or network-attached storage NAS.
To enhance video surveillance package includes the software D-ViewCam, designed to manage 32 cameras with a wide array of features, such as viewing images from multiple cameras simultaneously and send them to e-mail notifications of suspicious events or emergency situations.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
