DCS-56WEOL EOS
מארז חיצוני למצלמות DCS-31xx, DCS-37xx עם 2 אנטנות
היכן לקנות
תאור
Series enclosures D-Link DCS-56 is a versatile and cost-effective solution for the installation of surveillance cameras D-Link outside. Model DCS-56P supports Power over Ethernet (PoE), and the model DCS-56W enables wireless connections, providing convenient connections and observations. Housing with integrated power supply, heater and fan provides performance camera in adverse weather conditions.
Connection flexibility
DCS-56P supports Power over Ethernet (PoE), capable of transmitting power and data over a single cable Ethernet. PoE support enables you to place cover in different places without running additional power cables. The presence of the antennae cover DCS-56W significantly enhances connectivity and provides remote control and monitoring without the need for laying Ethernet cable.
Weatherproof housing
Designed for mounting the camera outdoors, the series covers DCS-56 is an all-weather enclosure (standard IP66), protecting the camera from dust and rain.
Built-in heater and fan
Series covers DCS-56 has a built-in heater and fan for the camera work in a wide temperature range. Heater and fan on and off automatically when the temperature is below or above a certain threshold.
מאפיינים כללים
Housing
• Material: aluminum-zinc alloy
• Standard: IP66
• Heater: Yes (On: 0 C, Off: 10 C)
• Fan: Yes (on 40 C, Off: 30 C)
Data transfer
• Data transfer rate: 10/100 Mbit / s
• Range: Up to 100 m
• Data channel Ethernet: TIA/EIA-568, Cat.-5 cable
נתונים פיזיים
Input Power
• 12V DC, 1A (power adapter is not included)
Power consumption
• 7.5 W
Operating temperature
• -20 To 50 ° C
Storage temperature
• -20 To 70 ° C
Humidity
• 80% non-condensing
Weight
• 2358 g
Certificates
• CE (Class A), FCC (Class A)
Measurements
• 415.4 x 161.7 x 126.3 mm
תקנים
הורדות
איורים
DCS-56W
מראה מקדימה
מראה מאחורה
מראה מימין
דף מידע
ראה גם
