DCS-6210EOL EOS
מצלמת מעקב רשת בצורת כיפה באיכות Full HD עם תמיכה ב PoE
היכן לקנות
תאור
The DCS-6210 Full HD Mini Fixed Dome Network Camera is an industry rated vandal proof and weatherproof camera suited to a wide range of traditionally difficult deployment scenarios.
Built for Tough Environments
Specially designed for use in challenging environments the DCS-6210 has a toughened metal, industry-certified IK-10 (vandal-proof) and IP-66 (weather-proof) housing. This means that it
is able to withstand sudden high impact, and adverse weather conditions. Additionally, the DCS-6210 carries a Power over Ethernet (PoE) port which allows you to connect the camera
to your network and power it through a single cable. This both expands and simplifies your deployment options by doing away with the need for a nearby power outlet, making
deployment on ceilings much easier.
Surveillance in Full High Definition
The DCS-6210 is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 1080p Full HD. This gives you sharp, high-resolution pictures and
videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan across your camera’s video so you can survey a large area easily.
A Complete, Expandable Surveillance Solution
The DCS-6210 is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device.
If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features,
including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
Built for Versatility
The DCS-6210 comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. It’s 3 axis lens mounting allows you to position it perfectly, while its motion detection capabilities allow it
to automatically record video and send you a notification when motion is detected.
מאפיינים כללים
Hardware profile camera
• 1/2 inch, 7-megapixel CMOS-sensor with progressive scan technology
• Fixed lens with a focal length of 4.3 mm and aperture F2.0
• 10x digital zoom
• Viewing angle:
  • 79 (H)
  • 43 (vertical)
  • 90 inch (diagonal)
Camera Body
• Weatherproof (standard IP-66) and anti-vandal (standard IK-10) package
Image details
• Setting the image quality and size, frame rate and bit rate
• Timestamps and paste text
• Customizable windows for motion detection
• Configurable zone private masks
• Setting the white balance, brightness, color saturation, contrast, sharpness, and backlight compensation (BLC)
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• H.264/MPEG-4 multicast transmissions
• JPEG for still images
Video Resolution
• 16:9 - 1920x1080 (up to 15 frames / s), 1280x800, 1280x720, 800x450, 640x360, 480x270, 320x176, 176x144 and 30 kadrov/s1
• 4:3 - 1440x1080 (up to 25 frames / s), 1024x768, 800x600, 640x480, 480x360, 320x240, 176x144 and 30 kadrov/s1
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• Supports 802.3af PoE
• Card slot Micro SD / SDHC
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System requirements for the web-interface
Web-browser: Internet Explorer, Firefox, Safari, Chrome
Event management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via Web-browser
• Interface settings, available through Web-browser
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
Software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen up to 32 cameras
• Recording Options for triggering a sensor or manually
• Supports all management functions available through the web-interface
נתונים פיזיים
Weight
• 412.2 g ± 5%
Power consumption
• 8.6 W ± 5%
Temperature
• Operating: -25 to 50 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
תקנים
הורדות
איורים
DCS-6210
מראה מקדימה
מראה מימין
מראה מאחורה
דף מידע
ראה גם
