DCS-2332LEOL EOS
תאור
The DCS-2332L HD Wireless N Outdoor Network Camera is a mydlink-enabled IP surveillance outdoor camera that lets you monitor an area 24 hours a day.
24/7 HD Surveillance
The DCS-2332L is built with a megapixel image sensor to give you high-quality snapshots and video with resolutions up to 720p HD. This gives you sharp, high-resolution snapshots and videos with rich detail. Get a closer look with ePTZ, which lets you zoom in, zoom out, and pan
across your camera’s video so you can survey a large area easily. An infrared cut removable (ICR) filter is also built into the DCS-2332L, which blocks infrared light during the day for improved image quality. At night, it moves out of the way to use all available light for low-light surveillance, and paired with the IR LED illuminator, this camera can monitor an area even in complete darkness.
Built for the Outdoors
Specially built for outdoor use, the DCS-2332L has an IP-65 weatherproof housing that protects it from dirt and rain. Wireless N connectivity means you can put it anywhere within range of your wireless network, giving you the freedom to install it right where you need camera
coverage.
Anywhere Access with mydlink
The HD Wireless N Outdoor Network Camera is mydlink-enabled, which means that you can access and configure your camera remotely, no matter where you are. See your camera’s live view through the mydlink website, or download the mydlink mobile app and view your camera
directly on your iOS or Android mobile device. Keep an eye on your home while you’re at work, or check on the office when you’re out on the road; mydlink makes it all possible.
Zero Configuration
If you have a mydlink-enabled Cloud Router, setting up and configuring your DCS-2332L is a snap, thanks to Zero Configuration. Simply connect your camera to its power adapter and then connect your camera to your Cloud Router with an Ethernet cable - the camera will automatically be added to your account. mydlink does the hard work for you, allowing even novice users to set up and use their mydlink-enabled cameras immediately.
Built for Versatility
The DCS-2332L comes with a wealth of features that enhance its surveillance capabilities, making it ideal for any situation. A passive infrared (PIR) sensor detects motion near the camera, allowing it to automatically record video and send you a notification when motion is detected. A built-in microphone and speaker allow for 2-way communication, which is ideal for use in entryways.
A Complete, Expandable Surveillance Solution
The DCS-2332L is a self-sufficient surveillance solution, capable of recording snapshots and video to a MicroSD card without requiring a PC or network storage device.
If you want to expand your surveillance options, D-ViewCam management software is also included, giving you the ability to manage up to 32 cameras with a robust set of features, including multi-camera views and automated e-mail alerts to keep you informed of suspicious or unusual activities.
מאפיינים כללים
Hardware profile camera
• 1/4-inch megapixel CMOS-sensor with progressive scan technology
• Distance of infrared light: 5 m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• Built-in passive infrared sensor (PIR) (5 m)
• Built-in microphone and speaker
• 10x digital zoom
• Focal length: 3.45 mm
• Aperture: F2.0
• Exposure time: 1/7, 5 and 1/10000
• Viewing angle:
57.8 (H)
37.8 (vertical)
66 (diagonal)
Housing
• Weatherproof housing with degree of protection IP-65
Image details
• Setting the image quality and size, frame rate and bit rate
• Timestamps and paste text
• Customizable windows for motion detection
• Configurable zone private masks
• Set the shutter speed, brightness, color saturation, contrast and sharpness
Video Compression
• Compression formats H.264/MPEG-4/MJPEG
• Multicast streaming video formats H.264/MPEG-4
• JPEG for still images
Video Resolution
• 16:9 - 1280 x 800, 1280 x 720, 800 x 450, 640 x 360, 480 x 270, 320 x 176, 176 x 144 and 30 kadrov/s2
• 4:3 - 1024 x 768, 800 x 600, 640 x 480, 480 x 360, 320 x 240, 176 x 144 and 30 kadrov/s2
Audio support
• G.726
• G.711
Interfaces to external devices
• Port 10/100 BASE-TX Fast Ethernet
• IEEE 802.11n/g/b
• Card slot for MicroSD / SDHC
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• Filtering of IP-addresses
• QoS
• CoS
• Multicast
• IGMP
• Compliance with ONVIF
Safety
• Security Administrator and user group
• Password authentication
• Encryption HTTP and RTSP
System requirements for the web-interface
Web-browser: Internet Explorer, Firefox, Chrome
Event management
• Motion detection
• Event notification and download stop-kadrov/videoklipov via email or FTP
• Support for multiple FTP and SMTP servers
• Multiple event notifications
• Several ways to backup
Remote management
• Creating and maintaining stop-kadrov/videoklipov to a local hard drive or NAS via Web-browser
• Interface settings, accessible via web-browser
Support for mobile devices
• OS Windows 8/7/Vista/XP, PDA, tablet PC or mobile phone
• Mobile application mydlink mobile devices with iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 8/7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
Software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• View images from multiple cameras on a single screen (up to 32 cameras)
• Supports all management functions in the Web-interface
• Recording Options for triggering a sensor or manually
