DCS-5020LEOL EOS
מצלמת מעקב אלחוטית בתקן 802.11n עם מנוע, צילום לילי ותמיכה ב - mydlink
היכן לקנות
תאור
Network Camera DCS-5020L supports a wide range of functions for the effective day and night surveillance in a home or small office. Pan and tilt mechanism provides coverage of a large area surveillance and integrated infrared illumination allows for round the clock surveillance regardless of the lighting conditions. Wireless connectivity allows you to connect to an existing wireless network without the need for network cables, if necessary, extend the range of the network.
Round the clock surveillance
DCS-5020L is a stand-alone camera that does not require any special hardware or software and can work on their own, even without a computer. Using the Camera DCS-5020L and Internet connection lets you send a notification to snapshots or video clips via e-mail when motion or sound. You can set up motion detection area, for example, the entrance to the building, and you can set a threshold sound level above which the camera will be fixed, for example, to hear a baby crying or the noise generated by an attacker. Built-in infrared illumination allows to conduct surveillance at night at a distance of 8 meters.
Constant remote access to video using a cloud service mydlink
Support Camera DCS-5020L mydlink ™ service makes monitoring your home or office easier, more convenient and allows you to stay connected regardless of their location. To view the video from the camera can use the Web-site mydlink, as well as additional applications mydlink mobile devices with iOS or Android. Mydlink app allows the user using Wi-Fi, 3G or 4G connection to quickly and easily view the video from the camera.
Clear images at different angles
Thanks to the pan / tilt and digital zoom IP-Camera DCS-5020L provides an overview of a large area from different angles and 4x digital zoom for detailed image. You can also configure the automatic movement of IP-cameras DCS-5020L between preset positions, allowing you to patrol a large area.
Large range of a wireless network with 802.11n standard
The wireless connection 802.11n camera DCS-5020L can be placed anywhere in the home or small office. You can also use the repeater mode to extend the range of an existing wireless network.
Multifunctional surveillance system
The included DCS-5020L software D-ViewCam allows you to extend the functionality of the camera to create a complete video surveillance system. With the D-ViewCam can centrally manage multiple network cameras (up to 32 cameras and up to 64 users), to record a wide range of functions, including recording triggered sensors on a schedule or manually.
מאפיינים כללים
Hardware profile camera
• 1/5-dyuymovy VGA CMOS-sensor with progressive scan
• Distance of infrared light: 8 m
• Minimum illumination: 0 lux with IR lighting
• Built-in ICR-filter
• 4x digital zoom
• Fixed focal length: 2.2 mm
• Aperture: F2.0
• Viewing angle:
• 66,22 (horizontal)
• 49,08 (vertical)
• 77,04 (diagonal)
• Exposure Time: 1/15 to 1/15000 sec.
• Built-in microphone
Image characteristics
• Setting the image size and quality, frame rate and bit rate
• The timings and paste text
• Customizable windows for motion detection
• Adjust brightness, color saturation, contrast
Video Compression
• Compression formats H.264/MJPEG
• JPEG for still images
Video Resolution
640x480, 320x240, 160x112 and 30 frames / s
Audio Compression
PCM
Connections
• Port 10/100 BASE-TX Ethernet
• Wireless 802.11n
Pan / Tilt
• Rotation: from -170 to 170 (of 340)
• Tilt: -25 to 95 (of 120)
• Speed: 16 per second
• Setting step: turn - 1/2/3/4/5 (default) / 10/15/20/25/30 per click
• Tilt: 1/2/3/4/5 (default) / 10/15/20/25/30 per click
Network
Network Protocols
• IPv4, ARP, TCP, UDP, ICMP
• DHCP-Client
• NTP-Client (D-Link)
• DNS-client
• DDNS-Client (D-Link)
• SMTP-client
• FTP-client
• HTTP-server
• PPPoE
• UPnP Port Forwarding
• LLTD
Safety
• Password authentication
• Encryption HTTP
Advanced Features
System requirements for Web-based interface
• Operating System: Microsoft Windows XP, Vista, 7, 8
• Web-browser: Internet Explorer 7, Firefox 12, Safari 4, Chrome 20 or higher with Java support
Event Management
• Motion detection
• Detection of sound level
• Event notification and downloading snapshots / video clips via email or FTP
Remote access
Remote management
Interface to configure, available through the Web-browser
Support for mobile devices
• mydlink Lite app for iOS and Android
• mydlink + app for iOS and Android
System Requirements D-ViewCam ™
• Operating System: Microsoft Windows 7/Vista/XP
• Web-browser: Internet Explorer 7 or above
• Protocol: Standard TCP / IP
Software features D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: up to 32 cameras
• Supports all management functions available through the Web-based interface
• Optional sensor triggered recording, schedule or manually
נתונים פיזיים
Weight
• Device: 292.4 g
• Stand: 60.8 g
Nutrition
• 12 VDC 1 A, 50/60 Hz
Power consumption
• 8.64 W
Temperature
• Operating: 0 to 40 C
• Storage: -25 to 70 C
Humidity
• Operating: 20% to 85% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certifications
• CE
• CE LVD
• FCC
• C-Tick
Measurements
• 102,35 x 101,27 x 133,6 mm (Camera only)
• 102,35 x 101,27 x 230 mm (including bracket)
תקנים
הורדות
קושחה:
ניתן להוריד קושחה אחרונה מאתר FTP. לחץ כאן.
תוכנות התקנה:
להורדת תוכנת התקנה למערכת הפעלה Windows לחץ כאן.
להורדת תוכנת התקנה למערכת הפעלה OS X לחץ כאן.
מדריך:
להורדת מדריך למשתמש באנגלית לחץ כאן.
איורים
DCS-5020L/Ax
מראה משמאל
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
