חיפוש מהיר
תכונות המוצר:
מצלמת מעקב להשגחה על תינוקות באיכות HD
מאפיינים כללים:
Hardware profile camera
• 1/4-inch megapixel CMOS-sensor with progressive scan
• IR illumination distance: 5 m
• Minimum illumination: 0 lux with IR lighting
• Built-in microphone and speaker
• Digital Zoom
• Screw to the tripod
• Focal length: 3.3 mm
• Aperture: F2.2
• Angles:
  • 66,18 (horizontal)
  • 35,9 (vertical)
  • 76,22 (diagonal)
Interfaces for external devices
• Wireless 802.11n
• Card slot Micro SDHC2
• Reset button
• Buttons Lullaby melody, increase / decrease volume, Food
• Micro-USB Port
Image details
• Adjusting the image size
• Timestamps and pasting temperature
Video Compression
• Compression H.264 video
• JPEG for still pictures
Video Resolution
• 1280x720
• 640x360
Audio Compression
• AAC
Function baby monitor
• Detection of the sound with adjustable sensitivity
• Motion detection with adjustable sensitivity
• Record snapshots and video to Micro SD card on motion detection or sound
• Determination of the temperature with a customizable "wake" range
• E-mail notification when it detects sound / motion / temperature changes
• Two-way audio, allowing a child to hear and respond to it
Mobile Apps
• Appendix mydlink Baby Camera Monitor, available on the App Store ® and Google Play ™
• Compatible with iPhone and iPad, using iOS version 5.1.1 or higher
• Compatible with Android smartphones and tablet PCs using Android version 4.1 or higher
Network Protocols
• IPv4
• ARP
• TCP / IP
• UDP
• ICMP
• DHCP-client
• HTTP
• HTTPS (for configuration)
• UPnP Port Forwarding
• RTP / RTSP / RTCP
Security
• Protection Administrator
• Password authentication
• Authentication HTTP and RTSP
System requirements for the web-interface
• Operating System: Microsoft Windows XP, Vista, 7, 8
• Web-Browser: Internet Explorer version 7 or higher, Firefox, Chrome, Safari
נתונים פיזיים
Measurements
• 137,1 x 92 x 105,5 mm fully extended temperature sensor
Weight
• Device: 139.6 g
Power Input
• 5 VDC 1.5 A, 50/60 Hz via AC adapter
• an external power supply from a USB-battery output current, at least 2 A
Power consumption
7.5 W max.
Temperature
• Operating: 0 to 40 C
• Storage: -20 to 70 C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• CE
• CE LVD
• FCC
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
