DCS-4602EV/UPAEOL
מצלמת מעקב רשת בצורת כיפה באיכות Full HD עם תמיכה ב PoE ו WDR
היכן לקנות
תאור
External vandal dome network 2MP Full HD-Camera DCS-4602EV / UPA with support WDR, PoE, and night shooting is the ideal solution for creating a system of professional high-definition video and security of small, medium and large enterprises. The camera is equipped with a highly sensitive megapixel CMOS-sensor with progressive scan technology and supports WDR, which allows to obtain excellent image quality in all conditions. With its robust design "all in one" camera is ideally suited to meet the challenges of video surveillance systems and requires no additional accessories.
Streaming and recording of high quality
To maximize bandwidth efficiency and improve image quality, DCS-4602EV / UPA compresses video in real time, using codecs H.264 and MJPEG, and supports three separate profiles for transmission of video in real time and record. These features provide a wide range of uses cameras for security purposes, such as monitoring public places to detect incidents and coordinating responses, control of restricted areas, deterring criminal activities or monitoring of the property.
Continuous monitoring
Camera DCS-4602EV / UPA with WDR sensor delivers excellent image quality with uneven lighting that allows the identification of objects, lighted from behind, or to shoot with too bright light. In complete darkness ICR-filter is automatically shifted to the side to use a wide range of light surveillance. Also, the camera DCS-4602EV / UPA is equipped with built-in infrared LEDs enables the camera to conduct surveillance in total darkness at a distance of 20 meters. All this makes the DCS-4602EV / UPA ideal for day and night surveillance.
Reliable management software
Supplied with the camera DCS-4602EV / UPA includes software D-ViewCam - complete package software for video, allowing you to view the image, manage and record up to 32 cameras on a single computer. Video recording and email alerts can be triggered by motion detection, informing administrators of unusual activity.
Flexible connectivity
Camera DCS-4602EV / UPA is equipped with built-in PoE standard 802.3af, simplifies installation by providing the power and LAN connection on one Ethernet-cable and thus eliminates the need for drilling holes and laying additional power cables.
מאפיינים כללים
Interfaces
• Port 10 / 100BASE-TX FastEthernet featuring PoE (802.3afklass 2)
Indicators
• Power / Connection
Buttons
• Reset button
Power connector
• Power connector (DC)
Housing
• Weatherproof housing (standard IP-66)
• Antivandalnyykorpus (standard IK-10)
Main characteristics
• 1/3-inch megapixel CMOS-sensor with progressive scan
• Focal length: 2.8 mm
• Aperture: F2.0
• Viewing angle: - 96 ° (horizontal) - 54 ° (vertical) - 108 ° (diagonal)
• Angles adjustment (non-motorized) - Vertical: 60 ° - Horizontal: 350 °
• 10x digital zoom
• Minimum illumination: - Color Mode: 1 lux @ F2.0 - B / W operation: 0.5 lux @ F2.0 - B / W mode with IR illumination: 0 lux @ F2.0
• Minimum Object Distance: 0.2 m
• Built-in ICR-filter
• The distance of IR illumination: 20 m
• Waiting time: from 1/8 to 1/10000 with
Features Image
• Adjust image size and quality, frame rate and data rate
• Time stamp and text insertion
• Customizable windows for motion detection
• Customizable privacy zones masks
• Setting the shutter speed, brightness, color saturation, contrast, sharpness, WDR and 3D-filter
• Flip and mirror image
Video Compression
• Video compression format H.264 / MJPEG
• H.264 / MJPEG multicast broadcasting
• Compression in JPEG format for still pictures
Video Resolution
• 16: 9 - 1920 x 1080 to 1280 x 720, 800 x 448, 640 x 360, 480 x 272 320 x 176 30 frames / sec
• 4: 3 - 1440 x 1080 to 1280 x 960, 900 x 720, 800 x 592, 640 x 480, 480 x 352 320 x 240 30 frames / sec
Network Protocols
• IPv6
• IPv4
• ARP
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• IP-address filtering
• Multicast
• CoS
• QoS / DSCP
• SNMP
• ONVIF
Security
• Protection of the Administrator account and user groups
• Password authentication
• HTTP authentication and RTSP
Event management
• Motion detection
• Event notification and upload still images / video clips via e-mail or FTP
• Support for multiple SMTP servers and FTP
• Multiple event notifications
• Multiple recording methods for backup
Remote control
• Creating still pictures / videos and save to your local hard drive
• Interface settings available through the Web-browser
Additional software D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: Up to 32 cameras
• Supports all management functions available through the Web-based interface
• Record Options for triggering the sensor, scheduled or manually
System requirements for Web-based interface
• Operating System: Microsoft Windows 8/7, Mac OS X 10.7 or higher
• Web-browser: Internet Explorer, Firefox, Safari
System requirements for D-ViewCam ™
• Operating System: Microsoft Windows 8/7 / Vista
• Web-Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP / IP
נתונים פיזיים
Weight
• 525g ± 5%
Sizes
• Height: 78.7 mm
• Diameter: 110.9 mm
Power
• Power adapter (not supplied)
• Output: 12V DC 1.5A
• The power cable for Ethernet (PoE) 802.3af (Class 2)
Power consumption
• 5,5 W ± 5%
Temperature
• Working: -30 ° to 50 ° C
• Storage: -20 ° to 70 ° C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Contents of delivery
• Network Camera DCS-4602EV / UPA
• Waterproof connector cable
• CD
• Quick Installation Guide
• Mounting Kit
Certifications
• CE
• CE LVD
• FCC
• C-Tick
תקנים
הורדות
איורים
DCS-4602EV/UPAA1
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
