חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת בצורת כיפה באיכות Full HD עם תמיכה ב PoE ו WDR ו LowLight
מאפיינים כללים:
Interfaces
• Port 10 / 100BASE-TX support with PoE (802.3af Class 2)
Indicators
• Network / Power
Buttons
• Reset button
Power connector
• Power connector (DC)
Housing
• Weatherproof housing (standard IP-66)
• Brackets for cables
Main characteristics
• 1/3-inch 1.3-megapixel CMOS-sensor with progressive scan
• Focal length: 2.8 mm
• Aperture: F2.0
• Viewing angles:
• 96 ° (horizontal)
• 54 ° (vertical)
• 108 ° (diagonal)
• 10x digital zoom
• Minimum illumination:
• Color mode: 0.2 lux
• B / W operation: 0.1 lux
• B / W mode with IR illumination: 0 Lux
• Minimum Object Distance: 0.2 m
• Built-in ICR-filter
• The distance of IR illumination: 30 m
• Waiting time: from 1/8 to 1/10000 with
Features Image
• Adjust image size and quality, frame rate and data rate
• Time stamp and text insertion
• Customizable windows for motion detection
• Customizable privacy zones masks
• Setting the shutter speed, brightness, color saturation, contrast and sharpness
• WDR
• 3D-Filter
Video Compression
• Video compression format H.264 / MJPEG
• H.264 multicast broadcasting
• Compression in JPEG format for still pictures
Video Resolution
• 16: 9 - 1280 x 720, 800 x 448, 640 x 360, 480 x 272 320 x 176 30 frames / sec
• 4: 3 - of 960 x 720 to 800 x 592, 640 x 480, 480 x 352 320 x 240 30 frames / sec
Network Protocols
• IPv6
• IPv4
• TCP / IP
• UDP
• ICMP
• DHCP-Client
• NTP-client (D-Link)
• DNS-client
• DDNS-client (D-Link)
• SMTP-client
• FTP-client
• HTTP / HTTPS
• Samba-client
• PPPoE
• UPnP port forwarding
• RTP / RTSP / RTCP
• IP-address filtering
• QoS
• CoS
• Multicast
• SNMP
• ONVIF
Security
• Protection of the Administrator account and user groups
• Password authentication
• HTTP authentication and RTSP
Event management
• Motion detection
• Event notification and upload still images / video clips via e-mail or FTP
• Support for multiple SMTP servers and FTP
• Multiple event notifications
• Multiple recording methods for backup
Remote control
• Creating still pictures / videos and save to your local hard drive
• Interface settings available through the Web-browser
Additional software D-ViewCam ™
• Remote management / control of up to 32 cameras
• Viewing images on a single screen: Up to 32 cameras
• Supports all management functions available through the Web-based interface
• Record Options for triggering the sensor, scheduled or manually
System requirements for Web-based interface
• Operating System: Microsoft Windows 8/7, Mac OS X 10.7 or higher
• Web-browser: Internet Explorer, Firefox, Safari
System requirements for D-ViewCam ™
• Web-Browser: Internet Explorer 7 or higher
• Protocol: Standard TCP / IP
נתונים פיזיים
Weight
• 445g ± 5%
Sizes
• 98,1 x65 x65 mm
Power
• The power adapter (not supplied)
• Output: 12V DC 1.5A
• The power cable for Ethernet (PoE) 802.3af (Class 2)
Power consumption
• Max. 4,7Vt ± 5%
Temperature
• Working: -40 ° to 50 ° C
• Storage: -20 ° to 70 ° C
Humidity
• Operating: 20% to 80% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Contents of delivery
• Network Camera DCS-4701E / UPA
• Waterproof connector cable
• CD
• Quick Installation Guide
• Mounting Kit
Certifications
• CE
• CE LVD
• FCC
• C-Tick
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
