חיפוש מהיר
תכונות המוצר:
Vigilance 360В° Full HD PoE Network Camera
מאפיינים כללים:
Hardware Profile
• 1/3.2` 3 megapixel progressive CMOS sensor
• 8 meter (25 feet) IR illumination distance
• Minimum illumination:
  • Day Mode: 0.5 lux
  • Night Mode (LEDs off): 0.25 lux
  • Night Mode (LEDs on): 0 lux
• Built-in Infrared-Cut Removable (ICR) Filter module
• Focal length: 1.1 mm
• Aperture: F2.0
• Angle of view:
  • (H) 180В°
  • (V) 180В°
  • (D) 180В°
• Angle of adjustment:
  • (V) 15В°
• Minimum object distance: 0.3 m
• Built-in microphone and speaker
Image Features
• Configurable image size, quality, frame rate, and bit rate
• Time stamp and text overlays
• Flip and mirror
• Configurable motion detection windows
• Desktop, wall, and ceiling display modes
• Configurable privacy mask zones
• Configurable shutter speed, brightness, saturation, contrast, sharpness
• WDR
• 3D filter
Display Modes:
• Fisheye View
• Normal View
• Multi-View with Panorama
• Panoramic View
• Mixed View (with Fisheye)
• Multi View
Video Compression
• Simultaneous H.264/MJPEG format compression
• H.264/MJPEG multicast streaming
• JPEG for still images
Video Resolutions
• 1920 x 1536, 1440 x 1152, 1280 x 1024, 960 x 768, 640 x 512 up to 25 fps*
Audio Support
• G.711
• AAC
External Device Interface
• 10/100 BASE-TX Fast Ethernet port
• Supports 802.3af PoE (Class 2)
• microSD/SDHC/SDXC card slot, accepts cards up to 128 GB**
Network Protocols
• IPv4, IPv6, ARP, TCP, UDP, ICMP
• DHCP client
• NTP client (D-Link)
• DNS client
• SMTP client
• DDNS client (D-Link)
• SMTP client
• FTP client
• HTTP server
• HTTPS for configuration
• Samba client
• PPPoE
• UPnP port forwarding
• RTP/RTSP/RTCP
• IP filtering
• QoS/DSCP
• CoS
• Multicast
• SNMP
• IGMP
• ONVIF compliant
• Bonjour
Security
• Administrator and user group protection
• Password authentication
• HTTP and RTSP authentication
System Requirements for Web Interface
• Browser: Internet Explorer, Firefox, Safari
Event Management
• Motion detection
• Event notification and uploading of snapshots/video clips via e-mail or FTP
• Supports multiple SMTP and FTP servers
• Multiple event notifications
• Multiple recording methods for easy backup
Remote Management
• Take snapshots/video clips and save to local hard drive
• Configuration interface accessible via web browser
D-ViewCam System Requirements
• Operating System: Microsoft Windows 10/8/7/Vista
• Web Browser: Internet Explorer 7 or higher
• Protocol: TCP/IP
D-ViewCam Software Functions
• Remote management/control of up to 32 cameras
• Supports all management functions provided in web interface
• Viewing of up to 32 cameras on one screen
• Scheduled motion triggered, or manual recording options
Physical Parameters
Weight
• 188 g В± 5%
Dimensions
• Diameter: 97 mm
• Height: 48.3 mm
External Power Adapter (not included)
• Input: 100 to 240 V AC, 50/60 Hz
• Output: 12 V DC, 1.5 A
Power Consumption
• 4.6 watts max.
Temperature
• Operating: 0В° to 40В°C
• Storage: -20В° to 70В°C
Humidity
• Operating: 20 to 80% non-condensing
• Storage: 5% to 95% non-condensing
Certifications
• CE
• CE LVD
• FCC
• C-Tick
* Frame rates when streaming video may vary depending on network conditions and method used.
** microSD/SDHC/SDXC v3.1 compatible.
נתונים פיזיים
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
