DCS-6620GEOL EOS
מצלמת מעקב רשת אלחוטית 10/100 Pan/Tilt/Zoom, זום אופטי: 10, Dual Codec, 0.05Lux
תאור
Product Description:
D-Link, a leading provider of wired and wireless IP Cameras, introduces the DCS-6620 10x Optical Zoom Internet Camera. Featuring dual codec support, a 10x optical zoom lens, built-in microphone, and low-light sensitivity, the DCS-6620 is the ultimate remote monitoring solution for your security needs.
The DCS-6620 features motorized pan, tilt, and optical/digital zoom (PTZ), giving you greater remote viewing options. With a 10x optical zoom auto focus/auto iris lens, get greater clarity from your recordings than digital zoom alone. The 10x optical zoom lens delivers the level of detail necessary to identify people, license plate numbers, and other important details that are difficult to clearly view with digital zoom.
Easily configure and manage your camera with D-ViewCam 2.0 surveillance software
With support for both Motion JPEG and MPEG-4 recording, the DCS-6620 is well suited for various recording scenarios. Motion JPEG delivers greater file integrity, making it ideal for critical monitoring situations. MPEG-4 video has smaller file sizes, making it more useful for extended recording periods or for use in low bandwidth networks.
The DCS-6620 supports 2-Way Audio with its built-in microphone and A/V port*. Attach a speaker to the A/V port1 and remotely communicate with subjects near the camera. An ideal location to use the 2-Way Audio feature includes point-of-entry areas, where you might want to identify a person before granting access.
With the ability to record video in low light settings, the DCS-6620 can provide exceptional nighttime surveillance. Extreme low light sensitivity of .05 Lux enables recording in near total darkness.
You can remotely monitor your camera using a Web-based interface or through the included D-Link IP surveillance software. The Web-based interface allows up to 10 simultaneous users to view the live feed from the camera. Using the feature-rich IP surveillance software, monitor and manage up to 16 cameras, set recording schedules, configure motion detection settings, and change settings on a single or multiple cameras.
Works With:
Industrial Grade Outdoor Enclosure with Power Supply, Heater, & Blower
DCS-70
מאפיינים כללים
Software
Modes of Operation
MJPEG
MPEG-4
Securitya
14-Digit Password
20 User Accounts
10 Simultaneous Users
Network Protocols
TCP/IP
802.3
802.3u
DDNS
UPnP
NTP
SMTP
FTP
HTTP
Wireless Security
WPA™-PSK
TKIP
128-bit WEP Encryption
Camera
Video Resolution
Up to 30fps at 352x240
Up to 10fps at 704x480
Field of View
5° to 65°
Lens Size
6mm
Physical Specifications
Wireless Standards
802.11g
802.11b
Device Ports
10/100Mbps Fast Ethernet
Power
External Mic
A/V Out*
Diagnostic LEDs
2 LEDs for POST, Connection, and Heartbeat
Power Input
External Power Supply
12V DC 1.5A
Power Consumption
5.5W (Still)
8.0W (Moving)
Dimensions (W x D x H)
4.2in x 4.2in x 5.3in (107mm x 107mm x 135mm)
Weight
1.28 lbs (0.58kg)
Temperature
Operating: (0° to 60°C)
Storage: (-6° to 75°C)
Humidity
5% ~ 95% RH, Non-condensing
Emission (EMI)
FCC Class B
CE Class B
Safety
LVD (EN60950)
Warranty
2 Year Limited**
Ordering Information
Part Number
Description
DCS-6620G
Wireless PTZ Internet Camera, Optical Zoom, Dual Codec, 0.05 Lux
תקנים
הורדות
איורים
DCS-6620G/Ax
מראה משמאל
מראה מאחורה
מראה מקדימה
דף מידע
ראה גם
