DCS-70 EOL EOS
מארז דמוי כיפה למצלמת אבטחה חיצונית, עם מכסה מגן הכוללת ספק כח, חימום פנימי ומפוח, מותאם לשימוש תעשייתי
תאור
The D-Link® Securicam Dome Camera Enclosure DCS-70 provides a cost-effective solution for protecting your D-Link Internet Camera from the rigors of outdoor use. The fixed-type dome enclosure includes a heavy duty, angle-adjustable mounting bracket that can be used to secure the camera on a vertical or horizontal surface. Maximize the full potential of your D-Link Internet Cameras to secure and protect your business.
The DCS-70 is a dome-type enclosure and is designed for use with D-Link's motorized pan and tilt cameras. This IP66 certified enclosure protects your camera against dust and heavy jets of water. Camera installation is simplified with the built-in power supply, while the heater and blower keeps your camera in proper operating temperatures.
Product Description:
Works With:
Fast Ethernet Internet Camera
DCS-5300
Wireless G Internet Camera (Wired Mode Only)
DCS-5300G
10x Optical Zoom Internet Camera
DCS-6620
Wireless G 10x Optical Zoom Internet Camera (Wired Mode Only)
DCS-6620G
מאפיינים כללים
Specifications
Supported Devices
DCS-5300
DCS-5300G (Wired Mode Only)
DCS-6620
DCS-6620G (Wired Mode Only)
Power Supply
110V AC Input, 12V DC, 2A Output
Heater
On at 32°F (±9°F), Off at 50°F (±9°F)
Blower
On at 104°F (±9°F), Off at 86°F (±9°F)
Dimensions
8.86” (L) x 8.58” (W) x 8.58” (H)
Weight
7.27lb
Material
Aluminum Housing with Smoked Acrylic Cover
Color
Biege
תקנים
הורדות
איורים
DCS-70 /A
מראה מקדימה
דף מידע
ראה גם
