DCS-3420 EOL EOS
מצלמת מעקב אלחוטית המותאמת ליום ולילה
היכן לקנות
תאור
The D-Link DCS-3420 Wireless Day and Night Internet Camera is designed for the small to medium-sized business (SMB) and home market to capture video or take snapshots in a variety of lighting conditions and provide remote monitoring capabilities over the Internet.
Easily configure and manage your camera with D-ViewCam 2.0 surveillance software
Full-featured Wireless Surveillance Camera
The DCS-3420 can be placed anywhere on the network either through a wired Ethernet or wireless 802.11g/802.11b connection to view the camera’s video feed. You can also instantly take snapshots while remotely viewing video feed from a Web browser. The DCS-3420 provides enhanced viewing capabilities with 4x digital zoom for close-ups3. With 0.5 Lux light sensitivity, The DCS-3420 can capture video under minimal lighting conditions. Furthermore, you can enable 2-way audio and talk to anyone within close proximity to the camera’s built-in microphone by connecting external speakers to the DCS-34202.
Advanced Software Features
Innovative software is included to enhance the monitoring and management of the DCS-3420. Simultaneously view up to 16 cameras at once, set up manual or scheduled video/audio recording to a hard drive, and set the camera to record or send e-mail alerts whenever the motion sensor is triggered. The DCS-3420 supports MPEG-4 and MJPEG video dual codec that can easily be viewed using Windows® Internet Explorer Web browser.
Customize Your Application
Customize your surveillance application with the DCS-3420 by adding an optional IR illuminator to view and capture images at night1. In addition, the original lens of the DCS- 3420 can be replaced with another lens of your choice, such as a night vision lens, to enable monitoring in completely dark conditions1. Interchanging the day and night lens is simple, quick, and hassle-free. With a built- in BNC connector, video feed from the DCS-3420 can be transmitted on to a standard video security monitor or to any CCTV video server. By using the DCS-3420 (Wired Mode Only) with a D-Link DCS-40, DCS-45, DCS-50, or DCS-60 camera enclosure, you can easily implement outdoor monitoring.
Easy Installation, Easier to Use
The DCS-3420 adheres to the Universal Plug & Play (UPnP™) specifications, which allows computers running Windows® XP to recognize the DCS-3420 and automatically add it to the network. The DCS-3420 can be accessed and viewed from “My Network Places” as a device on the network. By signing up with one of many free Dynamic DNS services available on the web, you can create a personal web address (e.g., www.mycamera. myddns.com) for your camera. This allows you to remotely access your camera and monitor your site without having to remember the IP address, even if it has been changed by your Internet Service Provider.
Packed with advanced features and remote monitoring capabilities, enable quality video and audio surveillance in a variety of lighting conditions with the D-Link DCS-3420 Wireless Day and Night Internet Camera.
מאפיינים כללים
Camera Specification
1/3” Color CCD Sensor
0.5 Lux
AGC/AWB/AES/BLC
Electronic Shutter: 1/60 ~ 1/100000 Second
Standard CS Mount Type Lens, 6mm, F2.0
Networking Protocols
TCP/IP, HTTP, SMTP, FTP, NTP, DNS, DHCP, DDNS, and UPnP
Ethernet
10BaseT or 100BaseT Fast Ethernet Auto-negotiation
WLAN
2.4GHz/802.11g or 802.11b
Bit Rate: Up to 54Mbps*
Security: Up to 128-bit WEP, WPA-PSK
Antenna Type
2.4GHz Swivel Type, Monopole
Frequency
2.4GHz to 2.5GHz
Impedance
50 Ohms Nominal
Gain
2dBi Typical
Remote Management
Camera Configuration and Camera System Log (can be Accessed Remotely via Internet Explorer 6.x or Above Web Browser)
Supported Video Algorithms
MPEG-4 Simple Profile Mode
MJPEG
Video Resolution
Up to 30Fps at 176x120 / 176x144
Up to 30Fps at 352x240 / 352x288
Up to 10Fps at 704x480 / 704x576
Audio
8Kbps to 32Kbps
LED Indicator
Bi-color Status Indicator
General I/O
1 Opto-isolated Sensor Input (max.12VDC50mA)
1 Relay Output (max. 24VDC 1A, 125VAC 0.5A)
Security
Administrator and User Group Protected
Password Authentication
Power
12VDC 1.5A, External Power Supply
Viewing System Requirements
Protocol: Standard TCP/IP Internet Suite ActiveX
Operating System: Microsoft Windows XP/2000
Browser: Internet Explorer 6.x or Above
Environmental
Operating Temperature: 32°F to 102°F (0°C to 39°C)
Storage Temperature: -4°F to 158°F (-20°C to 70°C)
Maximum Humidity: 85% RH (Non-condensing)
Safety
FCC Class B
CE
Minimum System Requirements
Computer with:
1.7 GHz Processor
256MB Memory
Windows® XP SP2 or Windows 2000 SP4
Internet Explorer v6
Multiple Camera Operation Requires Computer with:
2.8 GHz Processor
512MB RAM
32MB Video Card
Package Contents
DCS-3420 Wireless Day & Night Internet Camera
Detachable Antenna
CAT5 Ethernet Cable
Power Adapter
Mounting Kit
Quick Installation Guide
CD-ROM** with:
Software
Product Documentation
Weight
Item: 1.2 lbs
Packaging: 1.5 lbs
Dimensions
Item (WxHxD): 3.2” x 2.4” x 6.7”
Packaging (WxHxD): 9.7” x 3.3” x 11.3”
Warranty
1 Year***
נתונים פיזיים
תקנים
הורדות
איורים
DCS-3420
מראה מקדימה
מראה מאחורה
מראה משמאל
דף מידע
ראה גם
