חיפוש מהיר
תכונות המוצר:
מצלמת מעקב רשת אלחוטית מגה-פיקסל לשימוש ביתי או למשרד הקטן
EOL EOS
מאפיינים כללים:
Support OS
         Windows 2000 / Windows XP / Windows Vista / 3GPP
Utility
Network Protocols
         IPV4, ARP, TCP, UDP, ICMP
         DHCP Client
         DNS Client
         SMTP Client
         HTTP Server
         PPPoE
         RTSP
         3GPP
         NTP Client
         DDNS Client
         FTP Client
         Samba Client
         RTP
         RTCP
LAN
        Port 10/100BASE-TX
        Compatible with IEEE 802.3
        Compatible with IEEE 802.3u
        Supports full duplex mode
        Auto-polarity of MDI / MDIX
        Flow control is at full duplex mode, 802.3x
Wireless
        802.11b / g with encryption of data on protocols WEP/WPA/WPA2
Output power transmitter
        16dbm for 11b, 12dbm for 11g (typical)
Receiver sensitivity
        54 Mbps: <-66dbm
        11 Mbps: <-82dbm
Support for video compression algorithms
        MPEG-4/MJPEG
Support for audio compression algorithms
        GSM-AMR: 8kbps,
        ADPCM: 8Kbps
Sensor
        ¼ inch CMOS-sensor with a resolution of 1.3 lm
Memory SDRAM
        64 MB
Flash-memory
        8 MB
Slot SD-CARD
        Supports cards up to 16 GB
Lens
        Focal length: 5.01 mm, F2.8
Microphone
        50dB + / - 3dB, omnidirectional
Additional inputs / outputs
        1 alarm relay output max. DC 24V/1A, 125V AC / 0,5 A
        1 optically isolated sensor input max. DC 12V/50mA
Audio
        Yes
Reset Button
        Return to factory default settings
        Simultaneous compression format in MPEG-4/MJPEG
        JPEG frame for shooting
Internet Video
        Adjustable image size and quality
        Imposition of provisional marks, and text
        Rotation and mirroring
Video
        VGA (640 X 480)
        640 x 480 up to 30 frames / s.
        320 x 240 up to 30 frames / s.
        160 x 120 up to 30 frames / s.
        XGA (1024 X 768)
        1024 x 768 up to 10 frames / s.
        512 x 384 up to 10 frames / s.
        256 x 192 up to 10 frames / s.
        SXGA (1280 x 1024)
        1280 x 1024 up to 10 frames / s.
LUX
         0.5 lux@F2.8
         3A CONTROL
         AGC (Automatic gain of the video)
         AWB (Auto White Balance)
         AES (automatic electronic shutter)
Frequency
         50 ~ 16000 Hz
The ratio of signal to noise ratio
נתונים פיזיים
Power Adapter
         5V 2.5A External power supply
Maximum power consumption
         6 W
         At the entrance: 100-240 VAC, 50/60 Hz
         The output: 5 VDC, 2.5A
Dimensions (ShxDxV)
        71.9 mm x 110.0 mm x 37 mm without the bracket and rack
Weight
        265.3 g without the bracket and rack
Operating temperature
        From 0 ˚ to 40 ˚ C
Storage Temperature
        From - 20 ˚ to 70 ˚ C
Humidity
        From 20 to 80% non-condensing
Emission (EMI), security certificates and other
        FCC Class B
        IC
        C-Tick
        CE
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
