DCS-3410EOL EOS
מצלמת מעקב רשת קבועה עם תכונות יום/לילה, PoE
תאור
Low-Light Surveillance
The D-Link® DCS-3410 Fixed Network Camera is a versatile monitoring solution for installations that require the ability to record in low-light situations. The low lux enables you to record anytime, day or night, with minimal lighting. Along with the additional options available including features such as simultaneous MPEG-4 & MJPEG streaming, a BNC connector, digital I/O ports, PoE support, and support for optional low light accessories, the DCS-3410 provides the versatility needed for professional surveillance applications.
Low-light Video Capture
The DCS-3410 features 0.3 Lux light sensitivity for low-light monitoring, enabling you to capture video anytime, day or night. Additionally, you can attach a CS mount standard lens such as an auto-iris lens, IR LED lens, or a night vision illuminator, to record video in environments with little or no light. The DCS-3410 also comes with a 12V interface to provide power for an optional LED illumination.
Easily configure and manage your camera with D-ViewCam 2.0 surveillance software
Multiple Streaming
The DCS-3410 supports simultaneous dual-streaming of MPEG-4 and MJPEG to provide both high quality and bandwidth efficient compression formats. MJPEG delivers greater file integrity, making it ideal for detailed monitoring situations. MPEG-4 video has smaller file sizes, making it more useful for extended recording periods or for use in low bandwidth networks.
Flexible Connectivity
The DCS-3410 has a BNC connector for video transmission to a standard video security monitor or CCTV video server. It also includes digital ports (2 input & 1 output) allowing connectivity to external devices such as IR sensors, switches, and alarm relays. The DCS-3410 also comes with a RS-485 interface, providing connectivity to an optional Pan/Tilt enclosure, which effectively adds pan/tilt functionality to the DCS-3410. Additionally, a 12V interface provides power for an optional LED illuminator.
3GPP Mobile Surveillance
Support for 3GPP Mobile Surveillance1 allows you to view a live video feed from your compatible Internet-ready mobile phone with a 3GPP player installed. This extends your monitoring capability without requiring the use of a computer, allowing you to check your camera’s video feed while on-the-go.
Additional Features
The DCS-3410 comes with a built-in microphone and audio port allowing 2-way audio communication2 when an external speaker is connected. The DCS-3410 also comes with a built-in Samba client for NAS so there is no need for a direct connection to a PC or any other hardware or software to capture and transfer images. Equipped with 802.3af Power over Ethernet (PoE) support3, the DCS-3410 can receive both power and data over a single Ethernet cable, enabling you to place this camera in locations without a power outlet.
Convenient Camera Management
The included D-Link D-ViewCam™ 2.0 software enables you to manage up to 32 network cameras, set e-mail alert notifications, set recording schedules, and trigger motion detection to record directly to your hard drive. D-ViewCam 2.0 also allows you to upload a floor plan of your business and create a realistic layout of where your cameras are located, further simplifying the management process.
מאפיינים כללים
General Specifications
Sensor: Color 1/3” CCD
3A Control: AGC, AWB, AES
Minimum Illumination: 0.3 Lux @ F1.6 (typical); 0 Lux (10 meter range with optional IR Lens)
Resolution: 470 TV Lines Lens mount supports optional Auto Iris Lens or IR Lens (10 meter range)
CS Mount Lens: 6mm, F1.6
Field of View: 58° Diagonal, 34° Vertical, 45° Horizontal
Electronic Shutter: 1/60 sec. ~1/100,000 sec.
Audio
Built-in Omni-directional Microphone
Supports Two-way Audio by SIP*
External Microphone Input
External Speaker Output
Video Resolution
Up to 30fps at 704x480
Up to 30fps at 352x240
Up to 30fps at 176x120
Network Connectivity
10/100 Mbps Fast Ethernet Auto Negotiation
802.3af Power over Ethernet (PoE)**
General I/O
2x input (4 pins), 1x output (2 pins)
12V DC Output for IR Light (2 pins)
RS-485 (2 pins)
4-Pin Auto Iris Lens Connector
Environmental
Operating Temperature: 32° to 104°F (0° to 40°C)
Storage Temperature: -4° to 158°F (-20° to 70°C)
Humidity: 20 ~ 80% RH (Non-condensing)
Certifications
FCC Class B
CE
IC
C-Tick
Physical Specifications
LEDs
Link
Power
Activity
Power Input
External Power Supply
Power Consumption 12.5 Watts Maximum
12V DC 1.5A
Dimensions (W x D x H)
Item: 3.1” x 6.6” x 2.3” (78.7mm x 167.6mm x 58.4mm)
Package: 9.3” x 11” x 3.1” (236.2mm x 279.4mm x 78.7mm)
Weight
Item: 1.25 lbs (0.57 kg)
Package: 2.9 lbs (1.32 kg)
Software
Video Algorithm Supported
Simultaneous Dual-Stream Support (MPEG-4 and MJPEG)
Simultaneous Profile Support for Web Viewing, 3G Mobile Viewing***, and Video Recording
JPEG Compression for Still Images
Security
Administrator and User Group Protected
Password Authentication
Remote Management
Camera Configuration and Camera System Log (viewed via a Java-Enabled Web Browser)
Take Snapshots and save to Hard Drive via a Web Browser
D-ViewCam™ 2.0
Network Protocols
IPv4
DHCP
ARP
DNS
DDNS (D-Link)
TCP/IP
HTTP
UPnP™ Port Forwarding
SMTP
Samba
FTP
PPPoE
NTP (D-Link)
RTP
UDP
RTSP
ICMP
RTCP
3GPP
Minimum Requirements
To View
Java-Enabled Web Browser (Internet Explorer v6.0 or later, Safari, Firefox, Opera, etc)
To Run D-ViewCam™ Software
Operating System: Windows Vista®, Microsoft Windows® XP****
Web Browser: Internet Explorer v6 or later
Protocol: Standard TCP/IP
Warranty Information
Warranty
1 Year-Limited*****
Ordering Information
Part Number
Description
DCS-3410
10/100 Fixed IP Network Camera, CCD, 0.3 Lux, Day & Night, MPEG-4 & MJPEG, 2-Way Audio, BNC Connector, PoE
תקנים
הורדות
איורים
DCS-3410/A
מראה מקדימה
מראה מאחורה
דף מידע
ראה גם
