DCS-25EOL EOS
עדשת וריפוקל עם מתאם Infrared למצלמות 3410 / 3420
תאור
D-Link’s SecuriCam IP Camera accessories provide cost-effective solutions for the diversity of application. The DCS-10 IR illuminator and DCS-20 IR lens can be used for both day and night surveillance, and the DCS-25 vari-focal CS lens provides easy installation without the need to change lenses for particular applications. Protect your home and business by maximizing the full potential of D-Link’s IP cameras and these beneficial accessories.
מאפיינים כללים
Supported Devices
DCS-3410
DCS-3420
Dimensions
36 (Ø)x52.3(D)mm (1.42 x.2.06 inches)
Weight
90g. (0.20lbs)
Distance
10 m
Focal Lenght
F3.5-8.0mm/F1.4-360
Iris/Focus Control
DC-Drive
Manual focus
View Angle
95-42 degrees
