DUB-1040EOL EOS
תאור
D-Link’s DUB-1040 4 Port USB 2.0 Pocket Hub provides additional USB 2.0 ports for your notebook computer, allowing you to connect additional USB devices such as digital cameras, hard drives, mice, keyboards, printers, scanners, and many other peripherals.
Add 4 USB 2.0 Ports To Your Computer
With the DUB-1040 4 Port Universal Serial Bus (USB) 2.0 Pocket Hub,
easily add USB ports to your computer. Now you can connect up to 4 more
USB peripherals such as your digital camera, printer, CD drive, mouse,
and flash drive to your notebook computer.
Seamless Connection
The DUB-1040 4 Port USB 2.0 Pocket Hub is designed to provide quick and
easy access to the 4 USB 2.0 ports. A USB cable is provided to connect
to the host computer or another USB hub. Configured directly by the
operating system, this USB Pocket Hub operates seamlessly with
Microsoft’s OpenHCI, Intel’s Universal HCI, and USB 2.0’s latest
specification, EHCI. The USB Pocket Hub supports computers using
Microsoft Windows or Mac OSX operating systems.
Easy To Use
Connect this tiny device to an available USB port on your notebook
computer and your installation is complete. It’s that simple. There are
no power switches or buttons to press. The DUB-1040 4 Port USB 2.0
Pocket Hub will always be ready to go. Designed especially for PCand Mac
notebook users, this device provides a simple, cost-effective USB
connectivity solution for your USB peripherals.
Slim-Sized, Lightweight, Take it with you anywhere
Through a built-in USB cable, which can be neatly placed inside a
built-in compartment, the DUB-1040 4 Port USB 2.0 Pocket Hub
conveniently connects to your notebook PC. Designed to fit into any
notebook bag, the compact size of the device will allow you to
conveniently carry it with you wherever you go. Experience the ultimate
in portability and expandability with the D-Link DUB-1040 4 Port USB 2.0
Pocket Hub.
Ultimate Performance
The DUB-1040 offers the enhanced performance of USB 2.0 with transfer
speeds of up to 480Mbps, while remaining backward compatible with USB
1.1 devices *.
* Maximum transfer rate based on USB 2.0 specifications. Actual data throughput will vary.
** Using a USB 1.1 port will affect device performance.
