תאור
Blazing USB 3.0 Speed
Connect your PC to USB 3.0 devices at blazing speeds of up to 5 Gbps - up to 10 times faster than USB 2.0. You can back up your photos, music, and HD movies to an external storage device faster than ever before.
Plug and Play Connectivity
Just insert the card into an available PCI Express x1 slot and run the Setup CD to add 2 USB 3.0 ports to your PC.
Connect all Your Peripherals
Backward compatibility with USB 2.0 and USB 1.1 mean that you can connect any USB device to the DUB-1310. If you need more ports, you can connect additional USB hubs to connect up to 127 devices.
מאפיינים כללים
ממשקים
- PCI Express x1
- שתי כניסות USB3.0 סוג A
תקנים
- USB3.0
- USB 2.0
- USB 1.1
- USB 1.0
- OHCI
- EHCI
- PCI Express 2.0
מהירות העברת נתונים
- SuperSpeed: 4.8Gbps
- HighSpeed: 480Mbps
- FullSpeed: 12Mbps
- LowSpeed: 1.5Mbps
