תאור
Blazing USB 3.0 Speed
Connect your laptop to USB 3.0 devices at blazing speeds of up to 5 Gbps - up to 10 times faster than USB 2.0. You can back up your photos, music, and HD movies to an external storage device faster than ever before.
Plug and Play Connectivity
Just slide the card into your ExpressCard slot and run the Setup CD; it’s that simple to add 2 USB 3.0 ports to your PC.
Connect ALl Your Peripherals
Backward compatibility with USB 2.0 and USB 1.1 mean that you can connect any USB device to the DUB-1320. If you need more ports, you can connect additional USB hubs to connect up to 127 devices.
מאפיינים כללים
ממשקים
- ExpressCard 34
- שתי כניסות USB3.0 סוג A
תקנים
- USB3.0
- USB 2.0
- USB 1.1
- USB 1.0
- OHCI
- EHCI
- PCI Express 2.0
מהירות העברת נתונים
- SuperSpeed: 4.8Gbps
- HighSpeed: 480Mbps
- FullSpeed: 12Mbps
- LowSpeed: 1.5Mbps
