חיפוש מהיר
תכונות המוצר:
רכזת 2 מבואות USB 3.0 וקורא כרטיסים
תאור:
Hi-Speed ​​USB 3.0 interface
Connect the device to the USB 3.0 hub and get the speed to 5 Gb / s - 10 times the speed of the interface USB 2.0. It is now possible to back up photos, music and HD movies on the external storage device faster than ever before. DUB-1342 is ideal for connecting external storage devices to your computer.
Ability to connect to other devices
Backward compatibility with USB 2.0 and USB 1.1 allows you to connect any USB-device to the DUB-1342. Three USB-ports allow you to simultaneously connect up to three USB-devices. If you need more ports, you can connect an additional USB hub that allows you to connect up to 127 devices.
The transfer of data from mobile devices
Five slots card reader can transfer data such as music, photos and data from mobile devices to your computer at speeds up to 480 Mbit / s. Supported card types: CF, MD, MS, SD, MMC, and microSD. In addition, you can use additional types of cards: miniSD, miniSDHC, MMCmobile, MMCmicro, RS MMC, and Memory Stick Micro (M2). Card reader for smart card provides access to a computer without a password, and allows you to keep user data secure during online shopping or banking operations.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
