DUB-104EOL EOS
תאור
D-link DUB-104 4port USB 2.0 hub , with AC-adapter
Designed to provide quick and easy access, the DUB-104 is equipped with four type "A" downstream ports for connecting USB peripherals or other USB hubs. The DUB-104 does not require any software or complicated installation process. It is a Plug-and-Play device that provides seamless connectivity to both PCs and Macs. You can simply connect the DUB-104 to your computer and start connecting your USB devices.
The DUB-104 is backward compatible with USB 1.1 devices, ensuring connectivity between your computer and legacy USB devices. Diagnostic LEDs located on the front of the device provide power state and port status.
The D-Link 4-Port USB 2.0 Hub (DUB-H4) is an excellent choice for adding more USB ports to your computer for connecting your existing peripherals as well as adding the latest USB cameras and external storage devices
מאפיינים כללים
Specifications:
STANDARDS
· USB 2.0
· USB 1.1
· USB 1.0
· OHCI (Open Host Controller Interface)
· EHCI (Enhanced Host Controller Interface)
TOPOLOGY
· Multi-Star
REQUIREMENTS FOR CONNECTION
· Cascade connection of up to 127 concentrators
OPERATING SYSTEM
· USB 2.0
· MAS OS X 10.4.6 with support for USB 2.0
· Microsoft Windows XP/2000 with support for USB 2.0
USB 1.x
· MAS OS X 10.4.6 with support for USB 1.x
· Microsoft Windows XP/2000 support USB 1.x
PORTS
· 1-port USB Upstream (type B)
· 4 Port USB Downstream (Type A)
Minimum system requirements
· For USB 1.1:
· Windows XP/2000 with support for USB 1.1
· MAS OS X 10.4.6 with support for USB 1.1
For USB 2.0:
· MAS OS X 10.4.6 or higher with support for USB 2.0
INDICATORS
· Power (with the power light is blue light)
· Power consumption
· In standalone mode: 500 mA per port
TREBUEMOE POWER
· 5 VDC, 2.5A, 12.6Vt
· POWER SUPPLY (Optional)
· 5 VDC, 2.5A
SIZE
· 77 x 38 x 9.6 mm
WEIGHT
· 27.2 g
WORKING TEMPERATURE
· 0 - 33 º C
Storage temperature
· -18 - 35 º C
WORKING HUMIDITY
· From 5% to 95% without condensation
STORAGE HUMIDITY
· From 0% to 95% without condensation
CERTIFICATES
· FCC Class B
· CE
· C-TICK
· VCCI
PACKAGE
· 4-port hub Pocket D-Link USB 2.0
· Installation Guide
