DWL-122EOL EOS
Wireless 2.4GHz (802.11b) USB Adapter
היכן לקנות
תאור
Pocket Size & Easy Plug In
With its integrated Microstrip antenna, the DWL-122 directly plugs into any USB port on your PC. It is an attractive, portable pocket-sized wireless device, and can fit into your pocket or carrying case, allowing for easy carry.
Industry-standard Interoperability
With industry standard compliance, the DWL-122 adapter is fully interoperable with other 802.11b compliant wireless devices.
Network Security
Security is not an issue when data is transmitted without the wires. In the air, transmitted data can be easily intercepted if not well protected by a security scheme. The DWL-122 provides the necessary security, using the enhanced 40/128-bit industry-standard WEP (Wired Equivalent Privacy) encryption protocol.
Easy Installation
With hot swap and plug-and-play capabilities, the DWL-122 adapter provides connectivity directly to another 802.11b wireless enabled device (ad-hoc mode) or through an 802.11b Access Point (infra-structure mode). The adapter's support for Windows and MacOS ensures that you'll be up and running on a wireless network in just a matter of seconds.
מאפיינים כללים
נתונים פיזיים
תקנים
הורדות
איורים
DWL-122
מראה מקדימה
דף מידע
ראה גם
