חיפוש מהיר
תכונות המוצר:
אנטנת רב-כיוונית Indoor 5dBi
תאור:
Omni-Directional Antenna ANT24-0502 with a gain of 5dBi is designed for indoor use and can increase the range of the wireless 802.11b and 802.11g.
The antenna can be connected to a wireless access point or router to improve the transmission and reception of signals in all directions and to provide wireless coverage when using devices in point - a lot of points.
Wireless devices with removable antennas with lower gain of this antenna can be used to improve the quality of transmitted and received signals. Antenna ANT24-0502 is equipped with RP-SMA connector and can connect to wireless devices with plug RP-SMA. To connect the ANT24-0502 is necessary to disconnect the standard detachable antenna from the wireless access point or router, and connect the new antenna ANT24-0502 to RP-SMA connector on your wireless device.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
