ANT24-0502EOL EOS
תאור
Omni-Directional Antenna ANT24-0502 with a gain of 5dBi is designed for indoor use and can increase the range of the wireless 802.11b and 802.11g.
The antenna can be connected to a wireless access point or router to improve the transmission and reception of signals in all directions and to provide wireless coverage when using devices in point - a lot of points.
Wireless devices with removable antennas with lower gain of this antenna can be used to improve the quality of transmitted and received signals. Antenna ANT24-0502 is equipped with RP-SMA connector and can connect to wireless devices with plug RP-SMA. To connect the ANT24-0502 is necessary to disconnect the standard detachable antenna from the wireless access point or router, and connect the new antenna ANT24-0502 to RP-SMA connector on your wireless device.
מאפיינים כללים
Frequency band
• From 2.4 GHz to 2.5 GHz
Resistance
• 50 ohms (normal)
VSWR
• 2.0: 1 (max.)
Maximum gain
• 5dBi
Allowable power
• 2 W
Diagram in the vertical plane (vector E)
• 40 º
Radiation pattern in the horizontal plane (vector H)
• 360 º
