חיפוש מהיר
תכונות המוצר:
נקודת גישה אלחוטית AirPremier N™ בתדר 2.4GHz בעל תקן 802.11n עד 300Mbps
מאפיינים כללים:
Standards
• IEEE 802.11n
• IEEE 802.11g
• IEEE 802.3ab
• IEEE 802.3af *
• IEEE 802.3u
• IEEE 802.3
Management
• Telnet - Secure (SSH) Telnet
• Web-browser
• HTTP - Secure HTTP (HTTPS)
• Support for SNMP
• Module D-View - Private MIB
• AP Manager II
• An array of access points
Security
• WPA ™ - Personal
• WPA2 ™ - Enterprise
• WPA2 ™ - Personal
• 64/128-bit WEP-encryption
• Disable SSID Broadcast
• Access control based on MAC-address
• Detection of non-registered on the network access points
Support for VLAN / SSID
• 802.1q/Multiple SSID (up to 8)
Quality of Service (QoS)
• 4 priority queues
• WMM Wireless Priority
Frequency bands of wireless networks
• From 2.4 GHz to 2.4835 GHz
Data transfer rate
• IEEE 802.11b: 11, 5.5, 2 and 1 Mbit / s
• IEEE 802.11g: 108, 54, 48, 36, 24, 18, 12, 9 and 6 Mbit / s
• IEEE 802.11n (2.4 GHz): Up to 300 Mbit/s2
Transmitter output power
IEEE 802.11b
• 24 dBm (± 2dB) for 1, 2, 5.5, 11 Mbit / s
IEEE 802.11g
• 24 ± 2 dBm at 6 ~ 24 Mbit / s
• 22 ± 2 dBm at 36 Mbit / s
• 21 ± 2 dBm at 48 Mbit / s
• 20 ± 2dBm at 54 Mbit / s
HT20
• 22 ± 2dBm at MCS0 ~ 1
• 21 ± 2dBm at MCS2 ~ 3
• 20 ± 2dBm at MCS4
• 19 ± 2dBm at MCS5
• 18 ± 2dBm at MCS6
• 17 ± 2dBm at MCS7
HT40
• 21 ± 2dBm at MCS0 ~ 3
• 20 ± 2dBm at MCS4
• 19 ± 2dBm at MCS5
• 18 ± 2dBm at MCS6
• 17 ± 2dBm at MCS7
Receiver Sensitivity
IEEE 802.11b
• -76dBm at 1 Mb / s
• -76dBm at 2 Mb / s
• -76 dBm at 5.5 Mbit / s
• -76 dBm for 11 Mbit / s
IEEE 802.11g
• -82dBm at 6 Mbit / s
• -81dBm at 9 Mbit / s
• -79dBm @ 12 Mbit / s
• -77dBm at 18Mb / s
• -74dBm @ 24 Mbit / s
• -70dBm at 36 Mbit / s
• -66dBm at 48 Mbit / s
• -65dBm at 54 Mbit / s
HT20
• -82dBm at MCS0
• -79dBm at MCS1
• -77dBm at MCS2
• -74dBm at MCS3
• -70dBm at MCS4
• -66dBm at MCS5
• -65dBm at MCS6
• -64dBm at MCS7
HT40
• -82dBm at MCS0
• -79dBm at MCS1
• -77dBm at MCS2
• -74dBm at MCS3
• -70dBm at MCS4
• -66dBm at MCS5
• -65dBm at MCS6
• -64dBm at MCS7
Modes of operation
• Access Point (AP)
• WDS with AP
• WDS / Bridge (No AP Broadcast)
• Wireless client
Gain of the dipole antenna
• 2 GHz dBi@2.4
Maximum transmitter power
• FCC: 25 dBm / ETSI: 17dBm (Dual Chain)
Indicators
• Power
• LAN
• 2.4 GHz
נתונים פיזיים
Maximum power consumption
• 9-watt PoE *
• 8 W without PoE
Operating voltage
• 48 VDC + / - 10% for PoE * or 5 / 2 A
Operating temperature
• From 0 to 40 ° C
Storage temperature
• -20 To 65 ° C
Operating humidity
• From 10% to 90% (no condensation)
Relative humidity
5% to 95% (no condensation)
Certificates
• FCC Class B
• CE
• WiFi ®
Weight
• 238 g
Dimensions
• 111 x 28 x 148 mm
1. This device is intended for indoor use. Installation of the device outside the premises can result in a breach of local regulations.
2. Maximum wireless signal rate derived from the specifications of standard 802.11g and 802.11n. Actual data throughput will vary. The conditions under which the network operates, as well as environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. The radius of coverage may be affected by environmental factors.
* Only certain versions of the product support PoE.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
