חיפוש מהיר
תכונות המוצר:
אנטנת רב-כיוונית Indoor 8dBi עבור נתבים ונקודות גישה אלחוטיות
תאור:
Antenna D-Link ANT24-0802 - is omni-directional antenna with a gain of 8 dBi, designed for indoor use in the 2.4GHz ISM frequency band. This antenna provides high transmission / reception of wireless network devices operating in the 2.4GHz ISM (industrial, scientific and medical purposes). It can be used with wireless devices, 802.11n, 802.11g and 802.11b, such as access points and remote routers, and allows you to use a single device instead of several. The antenna can be used to replace the standard antenna wireless devices to increase the range. It can be connected to the wireless device via a cable (supplied with the antenna) or directly.
Accessories
ANT24-0802 comes with a base that allows you to install the device in different locations. The antenna is installed in the base, which can be placed on a table or other flat surface, or can be mounted on the wall with screws. ANT24-0802 can also be attached to a metal surface with magnets in the bottom of the base.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
