תכונות המוצר:
אנטנת רב-כיוונית Indoor 8dBi עבור נתבים ונקודות גישה אלחוטיות |
תאור:
Antenna D-Link ANT24-0802C - is omni-directional antenna with a gain of 8 dBi, designed for indoor use in the 2.4GHz ISM frequency band. This antenna provides high transmission / reception of wireless network devices operating in the 2.4GHz ISM (industrial, scientific and medical purposes). It can be used with wireless devices, 802.11n, 802.11g and 802.11b, such as access points and remote routers, and allows you to use a single device instead of several. The antenna can be used to replace the standard antenna wireless devices to increase the range. |
ראה גם
