DAP-1320EOL EOS
מגדיל טווח אלחוטי Wireless N300 להגדלת טווח אלחוטי של רשת אלחוטית הקיימת
היכן לקנות
תאור
Wireless repeater DAP-1320 is a portable device that increases the range of the existing network. The device can be placed anywhere in your home. Compact, fits in the palm of DAP-1320 has a high capacity and supports wireless networking speeds of up to 300 Mbit / s.
Easy setup and use
There are several simple ways to set up a wireless repeater DAP-1320. You can use the application QRS Mobile, mobile devices supported on the platform iOS or Android. You can configure the one-touch WPS button on the repeater DAP-1320 and the router or access point coverage area to be enlarged. Alternatively, you can simply turn on DAP-1320 in the outlet, connect to the device over the wireless network from a computer or mobile device and follow the steps wizard.
Compact and easy to install design
Its compact size allows you to install a repeater at home or in a small office, the device does not occupy much space and is ready for use immediately after connection. Wireless repeater is connected directly to an electrical outlet, so there is no need to use additional cables and bulky power adapters. Thanks to a neat and compact design DAP-1320 will fit perfectly into any interior.
מאפיינים כללים
Transmitter output power
• IEEE 802.11b:
   20 dBm at 1, 2, 5.5, 11 Mbit / s
• IEEE 802.11g:
   20 dBm at 6-36 Mbit / s
   19 dBm at 48 Mbit / s
   18 dBm at 54 Mbit / s
• IEEE 802.11n:
   HT20:
   20 dBm at MCS0-MCS4 and MCS8-MCS12
   19 dBm at MCS5 and MCS13
   18 dBm at MCS6-MCS7 and MCS14-MCS15
   HT40:
   19 dBm at MCS0-MCS5 and MCS8-MCS13
   18 dBm at MCS6 and MCS14
   17 dBm at MCS7 and MCS15
Receiver sensitivity
• IEEE 802.11b:
   -87 DBm at 1 Mb / s
   -87 DBm at 2 Mbit / s
   -85 DBm at 5.5 Mbit / s
   -82 DBm at 11 Mbit / s
• IEEE 802.11g:
   -82 DBm at 6 Mbit / s
   -81 DBm at 9 Mbit / s
   -79 DBm at 12 Mbit / s
   -77 DBm at 18 Mbit / s
   -74 DBm at 24 Mbit / s
   -70 DBm at 36 Mbit / s
   -66 DBm at 48 Mbit / s
   -65 DBm at 54 Mbit / s
• IEEE 802.11n:
   20 MHz
   -82 DBm at MCS-0/8
   -79 DBm at MCS-ninth
   -77 DBm at MCS-2/10
   -74 DBm at MCS-3/11
   -70 DBm at MCS-4/12
   -66 DBm at MCS-5/13
   -65 DBm at MCS-6/14
   -64 DBm at MCS-7/15
   40 MHz
   -79 DBm at MCS-0/8
   -76 DBm at MCS-ninth
   -74 DBm at MCS-2/10
   -74 DBm at MCS-3/11
   -67 DBm at MCS-4/12
   -63 DBm at MCS-5/13
   -62 DBm at MCS-6/14
   -61 DBm at MCS-7/15
Frequency range
• From 2.4 GHz to 2.4835 GHz
Antennas
• Two internal antennas
Plug type
• Varies by region
Safety
• Wi-Fi Protected Access (WPA and WPA2)
• 64/128-bit WEP-encryption
• WPS (PBC)
Advanced features
• Support applications QRS (iOS, Android)
Management
• Web-interface
נתונים פיזיים
Measurements
• 48 x 42 x 53.5 mm
Weight
• 69 g
Power
• From 110 to 240 VAC, 50/60 Hz
Temperature
• Operating: 0 ° to 40 ° C
• Storage: -20 ° to 65 ° C
Humidity
• Operating: 10% to 90% (non-condensing)
• Storage: 5% to 95% (non-condensing)
Certificates
• FCC
• IC
• CE
• UL
• EMI / EMC
• Wi-Fi
• C-Tick
תקנים
הורדות
קושחה:
ניתן להוריד קושחה אחרונה מאתר FTP. לחץ כאן.
מדריך:
להורדת מדריך למשתמש באנגלית לחץ כאן.
איורים
DAP-1320
מראה מקדימה
מראה מאחורה
מראה משמאל
דף מידע
ראה גם
