חיפוש מהיר
תכונות המוצר:
אנטנת Yagi כיוונית רבת עוצמה בעיצוב פאנל Outdoor 18dBi
תאור:
D-Link, an industry leader in networking, introduces the ANT24-1801 18 dBi Directional Yagi Antenna designed to provide extended coverage for an existing 802.11b/g wireless network. The directional yagi design of the ANT24-1801 offers dramatically increased wireless signal coverage in a specific direction allowing for improved data throughput at further distances.
The D-Link 18 dBi Directional Yagi Antenna connects to a variety of  wireless PCI adapters, wireless routers and acess points on the market today. Whether the wireless router or access point has a SMA or TNC connector, the ANT24-1801 comes with a RP-SMA to RP-TNC conversion adapter to accommodate either connector type.
The D-Link ANT24-1801 includes a mounting kit that allows for precise positioning and concentrated signal strength allowing for improved data throughput at further distances. The D-Link ANT24-1801 also includes a lightning surge protector, and a 0.5m (1.5 feet) cable. The ANT24-1801 is weatherproof and made of corrosion-resistant material to withstand harsh outdoor conditions and wind speeds up to 120 miles/hr (200km/hr).
Avoid the cost and complexity of adding additional wireless acess points or wireless repeaters when you can easily use the D-Link yagi antenna indoors or outdoors. Enjoy the benefits of wireless connectivity at greater distances and speeds throughout your indoor or outdoor wireless coverage area.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
