חיפוש מהיר
תכונות המוצר:
אנטנת Outdoor כיוונית רבת עוצמה - 21dBi
תאור:
The D-Link ANTNT24-2100 2.4GHz High Gain Outdoor Directional Antenna is designed for use with wireless devices operating in the 2.4GHz frequency band such as 802.11 standard wireless access points and routers. It provides a very high Gain of 21dBi to give your wireless network an extended operating range. For best performance, users can use an antenna of the same Gain (21dBi) or higher at the other connection end to take advantage of this antenna’s powerful grid design signal transmission.
Point to Point Application
The ANTNT24-2100 2.4GHz High Gain Outdoor Directional Antenna is ideal for operating in modes such as point-to-point WDS, and others that require a high gain directional antenna. An example application of this antenna is to extend your local area network (LAN) by connecting LANs from two separate buildings. A powerful point-to-multi-point topology, such as connecting three separate buildings together, is also possible by attaching to the same wireless host two of these antennas, each pointing toward a different direction.
Outdoor Deployment
The ANTNT24-2100 2.4GHz High Gain Outdoor Directional Antenna has a durable build and a sturdy, waterproof design making it suitable for outdoor installation. Furthermore, its corrosion-resistant material and grid design enable it to withstand harsh outdoor conditions and high wind speeds. A surge arrestor is included for protection against outdoor elements such as lightning and thunder storms.
Accessories Included
For ready installation, the ANTNT24-2100 antenna includes a pole mounting kit, which allows it to be placed on a pole for better wireless coverage. It also comes equipped with an indoor adapter cable fitted with N Type and RP-SMA connecters for easy connection to a host.
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
