ANT24-0800EOL EOS
אנטנה רב-כיוונית Outdoor 8dBi עבור נתבים ונקודות גישה אלחוטיות
תאור
D-Link introduces the 2.4GHz Omni-Directional Outdoor Antenna (ANT24-0800), designed to provide increased coverage for existing 802.11b or 802.11g networks.
The ANT24-0800 offers 360° of expanded coverage, effectively improving data throughput at farther distances. The D-Link Antenna also helps improve signal quality, reducing dead spots in your wireless coverage.
D-Link’s 2.4Ghz Outdoor Antenna’s omni-directional design gives you increased wireless signal range in all directions, making it ideal for Wireless Distribution System (WDS) applications. Its powerful omni-directional design can effectively redistribute a wireless signal to multiple remote locations.
The ANT24-0800 includes a sturdy base for wall installation and a waterproof design to resist harsh weather conditions. The package also includes a surge protector and waterproof tape for outdoor mounting to help ensure total durability.
D-Link’s 2.4GHz Omni-Directional Outdoor Antenna is a robust solution for expanding your wireless coverage. By reducing dead spots in your wireless coverage and improving signal quality, D-Link’s 2.4GHz Omni-Directional Outdoor Antenna (ANT24-0800) provides extended coverage for existing 802.11b and 802.11g networks.
מאפיינים כללים
Operating frequencies
• 2.4 -2.5 GHz
Gain
• 8 dBi
VSWR
• 2,0 max
Polarization
• Linear, vertical
HPBW
• Horizontal 360o
• Vertical 15o
Input power
• 50 W (cw)
Resistance
• 50 ohm
Jack
• N-type ("Mom")
Cable adapter
• N-"Dad" in RP-SMA, length 0.5 m
The theoretical transmission distance at a speed of 1 Mbit/s/11 Mbit / s (when operated with internal access points) *
• Up to 1.2 km/400m
The theoretical transmission distance at a speed of 1 Mbit/s/11 Mbit / s (when working with external access points) *
•  Up to 2km/600m
תקנים
הורדות
איורים
ANT24-0800/B
מראה מקדימה
דף מידע
ראה גם
