חיפוש מהיר
תכונות המוצר:
אנטנה כיוונית בעלת ביצועים גבוהים Panelfor 2.4 Ghz ISM Band
תאור:
 The D-Link ANT24-1200 connects to any Air™, AirPlus™, AirPlusG+™, AirXtremeG™ or AirPremier™ Access Point or Wireless Gateway Router.
The antenna provides extended coverage for an existing 802.11b or 802.11g wireless local area network (WLAN), and uses a reverse SMA connector, and is easy to install to an access point or wireless gateway router with a reverse SMA connector.
It ships with a3 metre extension cable and mounting caps for easy installation.
* Results may vary according to different environment conditions and /or devices
Note: This product does not currently work with the enterprise DWL-1750 external wireless router and the DWL-1700AP external wireless access point
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
