ANT24-0501EOL EOS
אנטנת רב-כיוונית Indoor 5dBi עבור נתבים ונקודות גישה אלחוטיות
תאור
The D-Link ANT24-0501 is a high-Gain omni-directional antenna designed for 2.4GHz ISM band indoor use. This antenna provides high transmission/reception rates for wireless LAN devices operating on the 2.4GHz public industrial, scientific and medical (ISM) frequency band.
It can be used with 802.11b and 802.11g wireless LAN devices such as access points and remote routers. This antenna can be used to replace the default antenna of your wireless device to expand its operation range.
It can be connected to your wireless device through an extension cable (provided with the antenna), or directly attached to your wireless device.
מאפיינים כללים
Frequency band
• 2.4GHz to 2.5GHz from
Directivity
• Omni-directional
Resistance
• 50 ohm
VSWR
• 1.92 max.
Return loss
• -10 DB max.
Design of the antenna
• collinear
Maximum Gain (without cable loss)
• 5.0 dBi
Allowable power
• 1 W
Attenuation in the cable (1.5m)
• 2.1dB @ 2.45GGts
Beamwidth in the vertical plane (vector E)
• 36 degrees
Beamwidth in the horizontal plane (vector H)
• 360
תקנים
הורדות
איורים
ANT24-0501
מראה מקדימה
דף מידע
ראה גם
