מאפיינים כללים:
| Technical Specifications |
Standards |
IEEE 802.11g |
IEEE 802.11b |
IEEE 802.3 |
IEEE 802.3u | |
Wireless Signal Rates* With Automatic Fallback |
108, 54, 48, 36, 24, 18, 12, 11, 9, 6, 5.5, 2, & 1Mbps | |
Wireless Frequency Range |
Wireless Transmit Power |
Receiver Sensitivity* |
54Mbps OFDM, 10% PER, -68dBm |
48Mbps OFDM, 10% PER, -68dBm |
36Mbps OFDM, 10% PER, -75dBm |
24Mbps OFDM, 10% PER, -79dBm |
18Mbps OFDM, 10% PER, -82dBm |
12Mbps OFDM, 10% PER, -84dBm |
11Mbps CCK, 8% PER, -82dBm |
9Mbps OFDM, 10% PER, -87dBm |
6Mbps OFDM, 10% PER, -88dBm |
5.5Mbps CCK, 8% PER, -85dBm |
2Mbps QPSK, 8% PER, -86dBm |
1Mbps BPSK, 8% PER, -89dBm | |
External Antenna Type |
Single Detachable Reverse SMA | |
Modulation Technology |
Orthogonal Frequency Division Multiplexing (OFDM) |
Complementary Code Keying (CCK) | |
Security |
64/128-bit WEP |
Wi-Fi Protected Access (WPA-PSK, WPA-EAP) | |
Advanced Firewall Features |
Network Address Translation (NAT) with VPN Pass-through |
Stateful Packet Inspection (SPI) |
MAC Filtering |
Website Filtering |
Scheduling | |
VPN Pass Through/Multi-Sessions |
Device Management |
Internet Explorer v6 or later; or other Java-enabled Browsers |
DHCP Server and Client | |
Led |
Power |
Status |
WAN |
WLAN (Wireless Connection) |
LAN (10/100) | |
Certifications |
Operating Temperature |
32°F to 131°F (0°C to 55°C) | |
Operating Humidity |
90% Maximum (Non-condensing) | |
Dimensions |
Item (WxDxH): 4.9” x 7.9” x 1.4” |
Packaging (WxDxH): 8.3” x 10.9” x 2.7” | |
Weight |
Item: 0.7 lbs |
Packaging: 1.9 lbs | |
Warranty |
Minimum System Requirements |
Cable or DSL Modem |
Computer with:
Windows® XP SP2 or Windows 2000 SP4*** or Mac OS® X (v10.4/v10.3)**** |
Internet Explorer 6 or Mozilla Firefox |
CD-ROM Drive |
Network Interface Card | | |
Package Contents |
RangeBooster G Router |
Detachable Antenna |
CAT5 Ethernet Cable |
Power Adapter |
Mounting Kit and Vertical Stand |
CD-ROM***** with:
Installation Wizard |
Product Documentation | | |
* Maximum wireless signal rate derived from IEEE Standard 802.11g specifications. Actual data throughput will vary. Network conditions and environmental factors, including volume of network traffic, building materials and construction, and network overhead, lower actual data throughput rate. Environmental factors will adversely affect wireless signal range.
*** Computer must adhere to Microsoft’s recommended System Requirements. Please contact Microsoft for details.
**** The software included with this product is not Mac-compatible. נתונים פיזיים
