ANT24-1202EOL EOS
אנטנה רב-כיוונית Outdoor 12dBi
תאור
OPTIMAL PERFORMANCE
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is designed to be used in conjunction with devices at the 2.4GHz frequency, and compliance with the b and g standards. It offers a powerful omni-directional signal at a high 12dBi gain that can effectively redistribute a wireless signal to multiple remote locations at a wide range from an access point or bridge.
CONVENIENCE OF FLEXIBILITY
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna features a very durable build that grants users with great flexibility. Its waterproof design provides users with the facility of choosing placement in or outdoors. The antenna also includes an N-Type to RP-SMA adapter cable for added compatibility, and a surge protector to withstand against the outdoor elements.
SIMPLE WIRELESS SOLUTION
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna is ideal for operating in modes such as multi point-to-point WDS, access point, and others that require a wide coverage range with its built-in high gain antennas. This is a cost efficient solution, especially when setting up a comprehensive hub in hot-spot locations.
WHAT THIS PRODUCT DOES
The D-Link ANT24-1202 Outdoor Omni-Directional Antenna works in the 2.4GHz frequency, and is compatible with devices compliant in the g or b standard. Its high gain of 12dBi makes it ideal for a series of modes that require a wide range of coverage. The ANT24-1202 is durable enough to be used in both indoor and outdoor environments with its waterproof design, yet flexible enough for a variety of placement and rotational (up to 360 degrees) options. The ANT24-1202 also provides users with convenience, offering compatibility with N-type and SMA-type interfaces.
מאפיינים כללים
Technical Specifications
Frequency Range
2.4GHz to 2.5GHz
Standards
IEEE 802.11g
IEEE 802.11b
Impedence
50 Ohm (nominal)
VSWR
1.92:1 (maximum)
Radiation
Omni-directional
Polarization
Linear vertical
HPBW/Horizontal
360°
HPBW/Vertical
Peak Gain
12dBi (typical)
Radome Colour
White
Extension Cable
N-Plug to RP-SMA Plug
Antenna Connector
N-Jack (female)
Extension Cable Length
50 cm (0.5 m)
Dimensions
1718 x 48 mm (67.64 x 1.89 inches)
Weight
1.2 kg
Operating Temperature
-40° to 80°C
Storage Temperature
-40° to 80°C
Operating Humidity
90% at 25°C
Warranty
1-Year Limited*
Package Contents
ANT24-1202 Antenna
50 cm extension cable with N-type to RP-SMA
Mounting Kit
Waterproof tape
Quick Installation Guide
תקנים
הורדות
איורים
ANT24-1202/Ax
מראה מקדימה
דף מידע
ראה גם
