חיפוש מהיר
תכונות המוצר:
מודם-נתב VDSL2 אלחוטי בתקן 802.11N (עד 300Mbps) עם 4 יציאות רשת במהירות 10/100Mbps
תאור:
VDSL-port and 4-port switch
The router is equipped with VDSL- port for connecting to high-speed VDSL- line. Built-in 4 - port switch allows you to connect computers equipped with Ethernet- adapters , game consoles and other devices to your network. In addition, any Ethernet- port devices can be used to connect to a dedicated Ethernet- line.
Safety
Wireless Router DSL-6740U has a built -in firewall. Advanced security features minimize threats of hackers and prevent intrusions to your network and access to unwanted websites for users on your local network.
Wireless Interface
You can quickly create a wireless network at home or in the office , which will allow your employees or members of your family to connect to a wireless network from virtually anywhere ( in the range of a wireless network). The Router can serve as an access point to connect to a wireless network device of the standards 802.11b, 802.11g and 802.11n.
The device supports several security standards (WEP, WPA/WPA2), filtration devices to be connected by MAC- address , and allows the use of technology WPS.
Configuration and Management
To manage and configure the router DSL-6740U uses a simple and user-friendly web-based interface (available in several languages) .
מוצרים ופתרונות | תמיכה  | חדשות  | אודות החברה |
